Andrei Goaga
- Jan 31, 2015
If this can be matched with the MgW, then it will be EXTRAORDINARY FABULOUS!
I think S-35 4 Perf (full apperture) would be really nice at 8k. So that would be about the same width as the current 5k i guess, but significantly higher then the current 6k FF. Is the only way really to qualify what people mean by S-35 is listing how many Perfs?Maybe, but it depends on how Red defines "Super-35" because they have been prone to calling sizes larger than 24mm-wide with that name.
That would require 50% more processing power than W8K VV since it would have 50% more pixels.I think S-35 4 Perf (full apperture) would be really nice at 8k. So that would be about the same width as the current 5k i guess, but significantly higher then the current 6k FF. Is the only way really to qualify what people mean by S-35 is listing how many Perfs?
Jeff - the real question here is about which "existing cinema" lenses will actually resolve 8K at S35. Most have problems with 4K as it is. So you may still need to get "new" lenses after all in order to get the best out of this. This to me almost looks like a great opportunity for RED to start making lenses again...
Just my 2 yen...
P
Any modern cinema lens resolves that pretty easily. That pixel size translates into about 130/140 lppm. Easy, peasy....Jeff - the real question here is about which "existing cinema" lenses will actually resolve 8K at S35. Most have problems with 4K as it is. So you may still need to get "new" lenses after all in order to get the best out of this. This to me almost looks like a great opportunity for RED to start making lenses again...
Just my 2 yen...
P
Free upgrade for all Weapon owners. :thumbsup:
Šabović Adis;1642061 said:Smaller pixelpitch?! Meaning weaker OLPF, meaning greater resolving power, meaning BBC's 4K pass?!
Go RED! :biggrin:
Yes, but it also might mean less sensitivity... which is why it's going to be about noise management. The new Sony A7RII, for example, has a lot of pixels but has kept the noise down, so it can be used at fairly high ISO settings (but not as high as the 12MP Sony A7S...)
Pixel size on a7s much larger than a7rII. It's what makes the Canon 1DC so nice, 4k is 1.3 crop of full frame.Yes, but it also might mean less sensitivity... which is why it's going to be about noise management. The new Sony A7RII, for example, has a lot of pixels but has kept the noise down, so it can be used at fairly high ISO settings (but not as high as the 12MP Sony A7S...)
what would be amazing if you could change from 8k to 6k to 4k to 2k and still be using the exact same full frame s35 sensor, no cropping,
but using smaller resolutions to get higher frame rates and lower compression.
True - however the Helium is a new sensor, and...maybe even cleaner than Dragon. Notice Jarred's photo shows the camera at 3200 ISO...
My gut tells me that'a a clue...this new sensor performs much better than we'd think....in lowlight...
