Brian Merlen
- Jul 31, 2010
- Age
- 40
- Stamford CT
- vestadalux.com
plus with the new mags coming to market the 65 will get faster speeds when SXT ships!
Drazen Strader said:Can we hear something about higher frame rates? and maybe no window cropping tech when going to lower resolution…not sayinh that adding prores is not nice…but I am getting the feeling there should more about the weapon!
Prores the motion version of shooting .jpeg on a DSLR … right?
Alexa 65 @24 fps RAW recorded data rate is exactly the same as with standard Alexa @120 fps. The on board Codex recorder can do it just fine.
Isn't ProRes also wavelet based compression?
Most editors like to work with proxies encoded with 422LT or 422Proxy as they are small, lightweight on the system, and very manageable.
Well, I was thinking about how ProRes could be implemented in the camera this morning. So, as I have nothing better to do right now, here are the options I think will be available:Capture at 5KHD on Dragon chip - image circle works on virtually all S35 glass, familiar DOF characteristics, 16x9 TV aspect ratio, etc
Down-sample to UHD in camera to overcome most of the Bayer penalty, avoid any downstream scaling requirements and cut data rates a little
Use RedLogFilm the way ARRI uses Log-C to carry more stops/precision in a 10/12 bit RGB container. (or just paint your rec 709 "hero" image in camera if grading isn't on the menu)
Pick the flavor of ProRes that suits your budget/expectations and Bob's your Uncle.
Cheers - #19
And RED gives you a lot of things that a 5D doesn't like no-moire thanks to its high resolution sensor, better color, ease of outputting a Cineon Log image, huge dynamic range etc. There is a reason DPReview gave Dragon such high marks. And with Weapon adding XLR and other niceities it'll also have a far better form factor. It's already got better monitor options, better UI, wireless operation, reduced rolling shutter, less noise and sharpness etc.
Also it just occured to me that if RED is producing a ProRes and RAW image at the same time... you could theoretically tether ProRes. And if FFMPEG has ProRes decoding that means every mobile platform could theoretically stream it.
The readout was shortened (as I recall) between R1 MX and Epic MX
