Leaving the Red-One ON and RECORDING until it fills the Red Drive ??
George D.
N. California, USA
Is it possible to leave the Red-One ON and RECORDING until it fills a 320GB Red Drive without harming the camera?
We are shooting something that there is no way of telling when it will happen. Therefore, we figured that if we just kept the camera recording it would capture the moment eventually. And, no, it is not possible to view the image through the viewfinder or monitor for the entire time.
Any advise or help is appreciated.
Thanks for your time.
There should be no harm to the drive or the camera.
I have never tried filling the drive up entirely, but I have often filled it to 80-90% of capacity, there should be no physical damage to the equipment as a result, but if you are really unfortunaty maybe you will get an error when it gets close to 100%. However I honestly think it will run smooth untill 100% and then stop recording with an error message saying disk is full.
Try it before you need it, and see what happens, it is highly unlikely that any damage to the equipment could occur.
Should do no harm to the camera.
If you are present and watching, you can also use pre-record on the R1 and trigger the record to start 30 seconds ago. Great for wildlife shooting.
I would turn off proxies generation on the camera - it takes a very long time for a full drive and better the camera doesn't even try if you are going to record 100% capacity.
Other than that there should be no problem.
I'd advise a test record, filling the drive, well before the shoot just to shake out any issues.
Also a good idea.
This may be out of the question, but I figured I'd throw it out there...if you can rent a R1 SSD side module and some SSD mags, you'd be in better shape when recording to full capacity. I've done this more than once on Epic and never had a problem. Haven't gone more than 80% or so on a Red Drive, and even then was not doing so in one full go. If the camera can be manned (or triggered remotely), it may be wise to do the occasional bump and roll (i.e. stop the camera recording and start again right away)...without generating quicktime proxies, the turnaround time is fairly quick between even long rolls. At least that way, you won't be risking an entire drive's worth of material.
Red One records in 2GB chunks. So in theory if there's a problem you still won't lose the entire clip.
filling it till 90% should be fine
I shot an hour at the time during shows on multiple cameras and never had problem due to capacity limit.
Any drive over 90% may cough.
Red did a f.. good job with those drives btw
I would never fill a drive up till it quits, it may be ok to do and automatically shut down recording which I'm certain it will but filling any drive in a computer up completely is NOT a good thing.
My 2 cents worth...
Best,
Frazier Nivens
BTW, I have a RED Drive 320 for sale now.
I did exactly what you are talking about two weeks ago with a 5 year old red drive. Recorded a very long presentation at 4k and the camera and drive did great. Footage is fine including the last clip/chunk.
However I would like to mention the caveat that this was the last footage shot on this drive before i sent it for RMA. I'll let you know if red tells me if I killed it. :)
I did this constantly on the R1 for a few years, shooting 2-3 hour live shows with up to 7 Reds. It's no problem whatsoever. Definitely turn proxies off.
Happy Shooting!
Me too Jimhare. The Red One is very forgiving I have found. Between filling cards 256 till they are full and having batteries quit while recording I have never lost anything. "Best Practice" NOT but sometimes shite happens.
Cheers!
