Stephen Williams
Does that mean 12%? :devil:
Depends on the emulsion.
Each stop of increase represents a doubling of the amount of light the camera can resolve without clipping highlights or losing dark details in noise. If you express this as a contrast ratio 11-1/2 stops is a 2896:1 contrast ratio between white clip and noise floor. 13 stops is an 8192:1 ratio. So 1-1/2 stops is a big deal. Much more than 12%.
The thing is, as a cinematographer, if I have to transpose numbers like "12%" or contrast ratios in my head, then they are not particularly useful for me. Which is why most cinematographers talk in f-stops.
Who needs a whole lighting crew when all you need is a box of candles and a fire marshal?
It's the opposite - linear gives much more precision in the highlights than in the shadows. Half of the available brightness values are spent on the one brightest stop, half of the remaining values to the next stop and so on.
There's 4096 brightness values total in 12 bit linear, assigned as follows if i've understood correctly - one stop each:
White
2048
1024
512
256
128
64
32
16
8
4
2
1
Black
That's true. And I agree with Stephen saying that he would just say "it's a 1.5 stop increase". But that still does not coincide with his other statement above about a 12% increase in DR, or perhaps it does, if you consider EVERYTHING as measured by stops. But you can't do that. Stops are NOT a linear scale, so a linear percentage calculation DOES NOT apply. You can't simply divide 13 stops by 14.5 stops and say it's about 12%.
I think I'll open a light renting house... I've got some matches to rent!
Pat
Since you guys kept going: I understand that the dynamic range of a sensor is the range between the noise floor of the system and the size of the "photon bucket". I guess what surprises, or don't understand, is why we can't create a sensor capable of reading "unlimited" values on the + side... What gives? (besides my lack of electronic engineering knowledge). Is it that the current necessary to express higher values becomes too strong for such compact and delicate electronics? Some sort of "pollution"?
It makes sense to talk in stops when you paint as all we see is contrast, right? But I agree with Jeff.
BTW, thanks Jeff for the graphical representation of stops.
:claps:
...why can't we create a sensor capable of reading "unlimited" values? [...] Is it that the current necessary to express higher values becomes too strong for such compact and delicate electronics? Some sort of "pollution"?
Would you describe the difference between 1/48 and 1/108 as less than 12% increase in shutter speed? How about ISO 500 to ISO 1125? T/2 to T/1.2? Those are all only 1.5 stop increases like 13 -> 14.5 stops. It is a 12% increase in the number of stops, but the increase in Dynamic Range is far greater than that.
Alrighty then! As one of the women that visits this fine web house, I suggest we all stop pecking at the keyboard and go out and shoot stuff! Lord knows our best work has to be earned, not theorized in a forum!
hugs,
Sarah
I see. Thanks. What is the instantaneous dynamic range of human sight?
Blah, blah, blah... the question is whether or not you can DO something with this sensor. Beating the numbers to death is making me numb.
Jim
This is me taking a break from bleeding bullets to do that Jim.
Bud if you want I'll go hang out somewhere else.
I know I ask a lot of questions. : )
