Brad Webb
Maybe I should have put one of these at the end?
Jim
Never underestimate the dynamic range of a smiley. :thumbsup:
Jim
You may find this interesting, though not of much practical value for filmmaking:
http://www.clarkvision.com/imagedetail/eye-resolution.html
This may be more interesting:
http://www.luminous-landscape.com/columns/eye-camera.shtml
That Wikipedia article that Cail posted a link to is interesting:
The retina has a static contrast ratio of around 100:1 (about 6 1/2 f-stops). As soon as the eye moves (saccades) it re-adjusts its exposure both chemically and geometrically by adjusting the iris which regulates the size of the pupil. Initial dark adaptation takes place in approximately four seconds of profound, uninterrupted darkness; full adaptation through adjustments in retinal chemistry (the Purkinje effect) are mostly complete in thirty minutes. Hence, a dynamic contrast ratio of about 1,000,000:1 (about 20 f-stops) is possible.
That Wikipedia article that Cail posted a link to is interesting: The retina has a static contrast ratio of around 100:1 (about 6 1/2 f-stops). As soon as the eye moves (saccades) it re-adjusts its exposure both chemically and geometrically by adjusting the iris which regulates the size of the pupil. Initial dark adaptation takes place in approximately four seconds of profound, uninterrupted darkness; full adaptation through adjustments in retinal chemistry (the Purkinje effect) are mostly complete in thirty minutes. Hence, a dynamic contrast ratio of about 1,000,000:1 (about 20 f-stops) is possible.
Jim
I am so confused. I can already see B+W picture of me at Red Studios saying in bold letters "do NOT sell/rent to this guy!". I've never had the pleasure of meeting you so I don't know your humor. I might be misreading you, you might be misreading me, in the end: I don't want to get blacklisted Jim.
I'll post my next question out of Recon to be safe.
Blah, blah, blah... the question is whether or not you can DO something with this sensor. Beating the numbers to death is making me numb. Jim
Is that the level of improvement that we are looking at? Mysterium - 9 stops VS. Mysterium X - 13 stops?
I see. Thanks. What is the instantaneous dynamic range of human sight?
With the newer builds and software I think it is more like 10-1/2 to 11 stops for Mysterium.
Jim,
Since your recent tests have found M-X to be 13 stops, I would like very much to know your rating of Mysterium so we can have a common basis for comparison.
Thanks,
I for one feel that learning and reading and understanding is also important - as important as hands-on experience. You need both.
There are several ways to measure DR (hence the propensity for a variety of results from different manufacturers). Measured S/N from the sensor. Measured output through the system using a variety of methods, including what Hollywood DI did last week. We have ordered the Arri DR test equipment and when we get that, plus finish calibration... we will do all of the tests and publish all of the results.
Jim
Hi Jim,
Could you let us have the results for both the M & MX sensor.
Thanks Stephen
using the same calibration and testing, it will be useful to know how the old sensor compares to the new sensor. cool stuff....
