David Mullen ASC
Moderator
By themselves, the numbers are near useless, but compared to another camera, there is a relative difference that the numbers will demonstrate.
I think though that there are two figures that should be released. One is the total measurable dynamic range of both the original sensor and the new MX sensor. The other is the range that begins at the same noise level at the bottom, to show the extra stops that are usable in the new sensor compared to the old sensor.
Because testing may show, let's say (I'm just making up a figure), a one-stop total increase in measurable dynamic range -- but when comparing noise levels, may show two or more stops increase in usable range if you pick the same level of noise as the base.
I'd also like to see the same test in 5600K and 3200K lighting balance.
