Joseph Seuferling
+ 1 to bring back manual fan control!
We've been watching all of the comments about the removal of manual fan mode in the beta.
'Adaptive' mode is meant to keep the sensor temperature as stable as possible for optimum image quality.
'Quiet Preview and Record' mode is designed to keep the camera in it's quietest possible state without any manual intervention.
Have there been any fan noise issues when running in quiet mode?
Can Anyone tell me if "Look Around" Has been disabled for this beta? I can't seem to find it.
Completely agree that adaptive will modulate the fan speeds as it's intended use is tight control over the sensor temperature.
Quiet mode is designed to run the camera hot, but at minimum fan speed. This includes extended recording cycles. Assuming the camera is calibrated in this mode it should give you the best image quality and sound performance. There is really no need to switch between the two modes during operation to cool the camera between takes.
with the new UI things are all shuffled around but this one is still available and in a more logical place I think :
Menu >> Settings >> Project >> Format.
(and you can easily add a quick link to this menu page with the new shortcut system)
It's under project/format nowadays.
cheers
Whaow did not understand at first that this beta was such big step. Really nice.
Happily I read some posts about the fan before I installed so when my camera started up dead silent after instalation I then know I needed to find my way to the fan menues.
really like everything I seen so far but some things puzzels me.
for example if I click on the shutter speed I now have the "advanced " button, why on earth is there not a path under that so I can get to switch from pars of a second to degrees... Like why not make all the needed sort cuts?
Also when looking for the fan menu I was stumbling around trying to find it. I doubt my rental clients would be able to locate it. So why not have it so that we can click the temperature readings next to the histogram and then get to a menu that splits between fan and blackshading.
Or click on the TC and you get to a menu for further navigation towards the TC menues.
same thing with the power menu under the power status. It would be really handy to have total time vs 10% of certain battery showings under the power status.
So basically my wish would be that I can click on pretty much anything on the screen and navigate from there.
None of this is a rant it's totally nuts that you actually do all these updates and give them to us. So I'm very thank full. And you probably have million of reasons why you laid these menu things out differently.
Happily I read some posts about the fan before I installed so when my camera started up dead silent after instalation I then know I needed to find my way to the fan menues.![]()
Björn-
I like your ideas; clicking on temp or power on a TOUCH screen should be easy enough to configure so that corresponding sub-menus show up.
I also would love to double tab the histograph (goal posts) to see it full-screen, and would love to be able to zoom to 100% while recording.
Is it a bug?:
When I go to Settings-Setup-GPIO/Sync-Sync, Sync mode - Genlock. Then I cannot Enable HDR. When I reset the Sync to: Sync Mode- off,I can Enable HDR.
While HDR is Enabled, I Enable Sync mode - Genlock, the HDR automatically disables.
Was it in previous builds, I do not remember?
