Yes, you should be able to setup a preset like that using an SDI monitor to control the camera. However, your preset would include, in that case, MENU mode for the SDI monitor. if you are OK with that then it should work.
Unfortunately since you can only create presets in camera and it requires one screen to be in menus mode to do so there are going to be some limitations.
Seems my camera wasn't liking presets I was loading from previous builds. I went though and recreated all the presets within the new build and the camera is rebooting properly.
Thanks Dan!
-Dane
Oh, and while doing this additional testing, my camera spontaneously shut off AGAIN. This is about the 4th or 5th time that's happened in the course of this custom key mapping stuff. I'll reiterate my willingness to send a log file if RED team would like to try to figure out why this is happening. I'm thinking it's build related, but if it seems otherwise to RED techs reading this, please let me know so I can open a support ticket.
It would be great to have Presets work with the new Firmware versions.
Every time there is an upgrade (which is great), I have to spend an hour getting each camera back to the Presets that I use. It's frustrating...
I was simply asking about something that I had read over at DVXuser about the Scarlet now able to shoot 120fps @ 2k. Seems that it can't, and IMO that's a shame. Speaking from the gospel of RED, I don't see any need for a 1k function. That was my only point.
Net result, I currently rent the EPIC instead of buying the Scarlet.
Good day to you sir :]
That shouldn't be the case. There are only a few settings with have been obsoleted and when you try to apply such a preset it will warn you. If you have preset files that don't work please open a support ticket and send the preset files in so we can fix any bugs in the BETA software.
