jordan levy
- Nov 22, 2012
oh phew, got it!Sorry, meant to clarify just on the Easy Top (Weapon)'s. Everything else is same day shipping!
Thanks for your support!
Here is the adapter I had made to keep the side lemo on the operator side. It's a simple "sheath" for the connector. 4 set-screws hold it in place. The original cable is not altered. Then just locks into the 19mm top mount. And has some leeway to spin a bit to alter the direction of a right angle Lemo. A great solution until a purpose made adapter with a front pointing Lemo is released by someone.
Nice hack.
Not sure it is shipping yet but I think wooden camera also has a direct pogo -> lemo cable in the work.
Instead of providing a female plug like the one you used from the top plate it is a male connector that goes straight into your monitor for even less clutter...
We have a Pogo to Pogo connector in development right now which should be releasing some time after NAB.
https://www.instagram.com/p/BDDkcUIt78b/?taken-by=woodencamera
RED (or somebody) should make a Lemo Adapter that converts the side POGO to a forward facing operator side Lemo at the camera front. All the benefits of the Epic configuration (which are many) with a little more space around the mount for lens changes. I can only think the "A" adapter put the lemo at the operator side rear of the camera facing up, because they wanted one adapter that would work on the side and on the top. But that is a really useless position for the Lemo.
Think again and think gimbals. I had the same mind set until I bought my Ronin and realized that the side back postion of the weapon side lemo is excellent, it makes perfect sense, the cable goes straight up to the handle bar without much interference with pan moments as when the lemo was sitting in the front. So I think that positon is really forward thinking.
Sure. But I know of a a half dozen of the most common configs I see go out the door on features and TV in which that "forward thinking position" is a serious buzz kill.
Thankfully ... it's modular and you can change it. That's what's cool about a pogo pin contact interface. You can have it your way.
More solutions and options will be at NAB.
Pretty sure you are gonna see more options for configs with DSMC2 than any digital cinema camera in history.
