Mattia Palombi
- May 8, 2010
- Brooklyn, NY
- matpalombi.com
on sharegrid you can find Monstro for less than $400 a day..
Good for you. But what's your point here?
My response from Red has been that it’s “normal” but I can send it in. Which I’ve been hesitant to do, it’ll just sit in purgatory. It’s most likely going to be a sale for me at this point. DITs roll their eyes to the back of their head when they hear Raptor and I tend to agree at this point with Red’s non-response.
I mean Zack Snyder shooting his next movie on V-Raptor you think he would ask the DITs for their choice of the camera?
Anyone had the sensor split on the alexa mini lf? I got it on a recent shoot. Had the Canon K35 35mm on a Pl mount
I've only been able to make it split with the LPL mount removed, no other way. Interesting you saw this on the Alexa Mini LF, this is the first time someone has posted an image. I haven't been able to make it happen in mine, but my Raptor all the time. Do you mind posting the ARRIRAW frame or a frame with metadata.
if the only solution to the artifact is “buy the XL” and if Red continues to be silent,
Its the DIT´s task / responsibility to QC all the material captured and report to DP and Producers... If using one or a few cameras that renders a center split glitch now and then simply is something no DIT are able to cover before wrapping each setup. So the problem will show up in dailies and post and producers will definitely take note as the additional cost to sort such split screen errors can be quite large even in Hollywood terms, there is simply no simple fix for it.
For that reason even for a Hollywood guy like Zack I would say it would be better to use monstros as main cams and only use the raptors for extra high frame rate stuff. Even if he does a lot of handheld, the weight difference on monstro and raptor is minimal in a Hollywood environment with all the bells and whistles they put on the cameras.
I doubt that would happen. He'll most likely want to use the latest and greatest model (being Raptor) given his relationship with Red. There's also a marketing consideration.For that reason even for a Hollywood guy like Zack I would say it would be better to use monstros as main cams and only use the raptors for extra high frame rate stuff.
Jarred Land said:Yup we are just wrapping up final testing… basically a new shroud inside the sensor chamber. It’s a good balance between both reducing extreme side flares to show a split and eliminating gate shadow.
If you never have seen the split on the stitched sensors we have making for the last 10 years then you probably can pass on sending the camera in as it’s a very rare thing that happens to raptor Monstro or Dragon VV and other cameras like the ARRI LF as adding this will make gate shadow more possible by the nature of , well, shading the sensor.
Greetings from another corner of the internet.
First some responses to some of the discourse above. The V-Raptors that are out on features right now don't have any fix that I know off. Seen a few bodies on a very specific Marvel film and they are much like mine. They've also been rolling for a while now. But as I've mentioned there's lots of ways of not making this happen.
In terms of silence on this front, RED hasn't exactly been, but likely to to many it can feel that way. They did make this official post at the end of 2021:
https://support.red.com/hc/en-us/art...Flare-Artifact
That states they were working on testing a solution and implementing it. I can say safely by my own testing regarding this particular artifact, and this stretches across not just RED cameras, that it likely is taking both time and experimentation to come up with the appropriate design that can be mass produced and reasonably installed on the body-side.
Elvis has not left the building. People at RED are still very much reading REDuser. Posting on the other hand, you'll likely only see them post when absolutely necessary of it s a quick bite. That's more of my theory on such things due to a variety of factors. This very much remains a RED focused discussion board, though we've certainly opened up the discussion much more broadly to other cameras in Jim's absence. Generally if there was other camera discussion DVXuser was the board for that. But this forum grew as did the industry and discussion.
The two best places to discuss RED related things are here at REDuser.net and the Facebook Group here: https://www.facebook.com/groups/reduser/
There are many RED related groups on Facebook, but these are the only two official groups. I'd say the OG RED Camera group is pretty good too, but it's HUGE and largely used as a marketplace. Not a bad thing, but the REDuser Group isn't exactly that sort of thing. It's actually fairly refreshing how on point things are as well as the general conduct of individuals.
Now something you'll care about.
Jarred posted this little update in a back in forth online earlier today:
This fix is in the direction I was hoping they'd take and will exist within the body. My "bush solves" involved making changes within a specific mount via light trap and flocking. Doing it in camera is a better solution IMO and will work for "everything" you throw at it.
It'll be nice to see how much of a difference this will make. Right now due to the variety of variables at play it's been pretty prone for some people. I've at this point seen other V-Raptors where people haven't seen the artifact, there's no magic, it can still occur on those bodies upon testing. But again, as mentioned, this isn't an issue for some people as their mount, lenses, and even filming techniques don't lead to the same result.
https://support.red.com/hc/en-us/articles/4412279558291-V-RAPTOR-Flare-Artifact
Hey Phil, just so I understand what Jarred is saying. This new shroud - when testing is done - will come pre-built into upcoming Raptors, yes? And it appears folks will - perhaps - be able to send in their current Raptors to get this added?
I also think it's notable that Jarred posted this online (on FB?), and not here on RU.
This was a back and forth discussion thread, just sharing here what was brought up as his reply is relevant here. I'm certain once everything is bolted down we'll get all the details posted in many places and not just a reply in a thread. Wouldn't exactly read into the tea leaves too much as to where this was posted as that means pretty much nothing.
