Cüneyt Kaya
- Sep 1, 2007
- good old Berlin
- www.allahead.de
can we get a module adaptor with integrated second monitor port?
I definitely know what you are saying, as the owner of (8) Anton Bauer Dionic batteries.
My guess is: One advantage will be for younger Scarlet owners who don't have the cash yet to invest in a larger brick battery system. When you go that direction, you never spend less than $2000-$3000, and often more. Perhaps their Redvolts will be able to do double duty in the side handle and also in more of a studio configuration.
Anyone get a shipping email?
And you have to admit, the Pro Battery Module does look pretty cool.
Do we actually have any technical infos about battery (Wh) life on the module?
Are there some mounting options under the module (to put a shoulder pad)?
Can we put some pressure under the module (put on the shoulder)?
Pat
But, for me, I think there are just a few too many disadvantages such such as the inability to bring more than three onboard planes, having to make sure that you get the right battery plate for your camera or else you won't have a percentage display of the time remaining and also the extraordinarily unlikely, but still valid concern that the battery plate may possibly damage the camera. And if it does, as long as you're using a third-party plate, the camera's warranty becomes void. And you have to admit, the Pro Battery Module does look pretty cool.
I believe each individual REDvolt is 30 Wh and typically lasts for between 30-45 minutes on a Scarlet and 30 minutes on an EPIC.
If you bolt the battery plate to the back of the camera it should not have ANY chance of tweaking the Camera back, and if you put the Adapter Module between there you can use the quick release without worry of possible damage to the camera.
3 REDbricks on an airplane = 15 REDvolts....
The nice thing about the Batt Module is no cables... but then no D-tap and it makes the camera bigger (albeit slightly) then a brick on the back and holds less power then a single REDbrick.
Thanks.
A tipically day of shoot eats about 4 REDbricks = 560Wh... so 18 REDvolts... ?
Pat
Thanks.
Pat
I'm not exactly sure what you mean... Are you talking about attaching a V-Mount or AB battery plate to the back of the brain with a Module Adaptor in between them?
True.
Also true.
So Tehben, you're saying that you prefer RED BRICKS? (I do mean that as an honest question.) I've been researching battery systems over the past few months and I've concluded on the REDvolts, but, I may have to re-reconsider.
Yes. (Well, more like 19, but yeah...)
YesI'm not exactly sure what you mean... Are you talking about attaching a V-Mount or AB battery plate to the back of the brain with a Module Adaptor in between them?
I haven't heard of any issues as long as you use the screws.
Might be worth it to keep the module adapter though, you might need it at some point and like others said it could allow you to QR your brick solution.
Dont forget Redvolt XLs, though, wattage equivalent of 3 redvolts. If you're using the side handle with a few volts, you could go with a single quad charger, maybe 2-3 redvolts for the side handle, and 4 XLs and you've got a ton of power.
Then again, I am going brick to start with, and adding Volts etc. later so...
I'm starting with the Wooden Camera v-mount system, but I ordered a side handle and quad today. Might cancel the quad for a dual once details on that firm up.
