Christoffer Glans
Waiting for more solutions to monitoring questions due to the high risk of using the built-in SDI, I'm trying to optimize using Komodo Link.
Problem is that the performance of the video feed is very underwhelming. I've updated to the latest firmware of both the Komodo and Red Control, but nothing changed the feed performance. Now, this isn't about the quality of the video, the setting you can change in the Komodo menu, but the framerate consistency of the feed.
There's a noticeable delay that I think is close to impossible to get rid of, but that is not the problem. The video feed stutters and "jumps" due to frame skipping and it is close to unreliable to use this as a monitoring device. This occurs on both iPhone and Android, so that's not the issue either.
It's bad at 25 and 24fps, but it's even more noticeable when overcranking. If shooting anything at 40 fps, it's close to unusable. A reminder: the Komodo Link is an expensive add-on to the camera and all it really does not is to erase wifi interrupts happening, that's it. There's no change to the video feed on Komodo Link compared to a stable wifi signal. So the only reason to get it is because wifi performance is bad, not that you get some better performance boost out of it.
So my question is, will this improve? Is it possible to optimize the firmware to get a consistent 24/25fps feed that does not stutter or frameskip? And what about overcranking, can we get raw framerates through the Komodo Link? Because we need raw framerates, not interpretations of framerates which leads to frame skipping.
Another thing is the lack of a monitor-only mode and proper lock. On Android especially, you can't lock the phone to not turn when turning the phone, which means that every time you accidentally turn the camera or hold the camera in the side handle and pull it up to take a shot, the app has reset to show all the features with just a small video window. So you need to enlarge it back to full screen. This is seriously slowing down workflows. Just make a switch on the home screen of Red Control to lock it into full-screen mode without settings. If you need settings you just flip that switch back to normal.
I think that the next firmware of Komodo and Red Control really needs to address these things. Frame skipping almost makes the Komodo Link setup with Red Control unusable as a reliable monitoring solution and the lack of a monitor-only mode makes the workflow very impractical and slow. The potential of using a phone as a monitor with Komodo Link is one of the best things about Komodo, but not if it's like it is at the moment. The potential is there, but it needs some serious tweaking and I hope this is a priority issue now.
EDIT: seems like landscape lock is indeed implemented in the Red Control updates, so that's one issue gone, credit to Mikael for that. :hurray:
