Jeremy Torrie
My two were allocated Friday. Should have them next week for my M's.
I did a quick test with my motion mount in ND mode and I started seeing these weird aliasing artifacts (or something like it) Has anyone seen this?
Hi Mark,
where you see artifacts? i used motion mount for spot in Italy in mode ND, but not see nothing. RED EPIC.
Another test, it's not perfect because the light changed a bit while the mount was being switched. But you can see that the Chromatic aberrations in the high contrast areas which are apparent with and without the motion mount are enhanced when the motion mount is on. There even seems to be a bit of a sharpening effect with the Motion Mount, as well as possibly a slight increase in contrast (which can look like sharpening) but I feel that the CA is stronger when the Motion Mount is present. These screen grabs are taken from RAW files in RCX 21. My nest test is to output PR422 files to see if things change during the encoding.
1st. pic Motion Mount
2nd. pic Canon Mount
OT...Luigi, who has it in Italy? thx!
