Adam Montville
- Jun 21, 2013
Just some wishing. I really hope the Hydrogen shoots .R3D, and uses IPP2, or at least the option in post. Would be awesome to use your LUTs on it!
Just wanted to thank you guys for supporting philmColor. In the last month in particular I've been sent frames and trailers for stuff coming to Netflix, theaters, and a whole lot of commercials. Love seeing how you are putting these looks to good use.
The update is coming along nicely. Have a bunch of stuff "done", but a few more things I want to create. Should be released in September free to all those who purchased.
Hey Phil I notice that most of your LUTs are subtle to most. It would be great to see some other extreme group or file of LUT's. Maybe like some major motions pictures or commercial work.
Im thinking Guardians of the Galaxy looks and projects with that extreme looks.?
I'm working on a few "bolder concepts". However, a great deal of GOTG and GOTGV.2's in particular look is due to judicious use of colored lighting on set and a lot of it. I can make you a look that will "tungsten-ize" your skin tones, but that might not work out for a lot of situations. But yeah, I'll yellow it up for a few things
General stuff:
baseStocks = Generally stronger, bolder looks with a few subtle ones. Egret in particular comes to mind as subtle. Most are meant to not have tonal adjustments so they can work on every type of exposure, however, things like the bleach bypass emulations/looks obviously have those.
ghostStocks = Essentially "color science". Subtle, but does interesting things like fixing green skin from weird lighting environments and various other aesthetic shifts. Zero luminance tonal stuff, but certainly chromatic tonal movements and adjustments.
printModels = Anything beyond A is real flavored. These also have unique tone curves for various feels.
tonalAdjusts = No color shift, but just tonal adjustments.
But just a tease. Perhaps too big of a tease:
I'm waiting for a whole bunch of film shot on multiple formats to come back from the lab. A whole bunch.
But in short, with the V2 update, yep some bolder looks and a heck of a lot of other things.
I remember when I saw the post on Instagram I just thought you were doing a shootout between IMAX and RED or something, but now would a guess that you're creating IMAX-inspired baseStocks be far off? (I suppose we will see soon enough, but the tease seems to point that direction, which is exciting)
but Vision 3 is Vision 3 if you catch my drift
I'm using a concatenated Philmcolor/IPP2 Lut for monitoring on the new car film/doc I'm working on. Producers all super happy with what they are seeing.
The one suggestion I would make is to have a single sentence description for every lut. There's so much in there that it can take a while to find what you're after outside the main ones you describe in your pdf.
EG - 'shadows pushed to green. gamma lowered. highlights strong yellow'
Hi Phil -- just one of the many to recently purchase Philmcolor. I have an Epic W and in camera, truly amazing! Also of course great in RCX. I just tried Dove for some green screen, amazing! Also wanted to thank for for group buy on ServPro -- that with the iPAD Pro and these LUTs are amazing. Can't wait for version 2 although there is plenty to chew on in version 1. Thanks so much for doing this!!!
Jon
Hello Phil... Question: Did my upgrade recently to Helium 8K S35 and after the crazy traveling finally I am gonna dive and purchase your LUTs. meanwhile, I was trying tonite to get adjusted to IPP2 workflow and its awesome, but when I go to REDCINE X and do the correct pipeline preference REDWIDEGAMMUT and Log3g10 with the IPP2 Monitoring setup: Color Space: Rec709 and Gamma: 1886 as showing in the RED Tech Video, The image gets very saturated specially on the reds... I am able to fine tune the Ipp2 Contrast and Highlight from low to high and its awesome.. I reduce the saturation to about 85% and I find an outstanding image. But for some reason the Image is very saturated from the beginning without touching the saturation.. Am I doing something wrong? That is not even adding a Creative 3D LUT at all... I ll do that with yours which I want to do after I get this right.... Then start doing it straight In-Camera.
Without screenshots or an R3D I'm "working blind", but you'll find some colors pumped up a bit with IPP2. However, you shouldn't be seeing "anything crazy".
Here are the settings and the colors at medium both contrast and highlights. No LUT no curve.. Plain with IPP2 pipeline
www.alainmaiki.com/redfootage
NOTE: Now, If I set up the preference with IPP2 Monitoring setup: Color Space: Rec2020 and Gamma: 1886 the colors look more correct. I am using my new MacBook Pro 2017 with this testing. Rec2020 seems for color accurate than Rec709 in the IPP2 Monitoring but I aint no expert on this... I might be doing something wrong.
Thanks Phil.
Hello Phil,
Do your LUTS contain within them Secondary Color Corrections? I would assume they must,
but what's odd is that RedCine X does not have a Secondary Color Corrector.
Well you need to figure out what your target output is and what your monitoring on. IPP2 is more colorful in general, but if you are finding it too saturated you can knock down the saturation via the CDL control. Give that a whirl. I've noticed also between Helium and Dragon I'll knock down or knock up saturation pretty often to get them to match.
