Group Buy: Budget CRI 95 LED Strip Lights
Just a question. you wrote that lumens are close to 2000 per meter. Litegear max lumens is 1200. Are you sure about those numbers?
By the way, I tried Yuji's strips (blue, 12V 5630 LEDs at 1200 lumens) and they are very good. Right on at 5600K and no green tint. Reds could be a little richer though.
Hope yours are better. ;-)
The Yuji strips can be powered at 15W/meter but this requires them to be attached to something that will dissipate the heat. Deep red seems to be a problem with all daylight LED which also affects purple.
I'm interested 2 x variable, 1 x daylight, 1 x tungsten and whatever controllers are offered.
Thank you for putting this together!
How big a battery do you need to power an entire strip?
12v car battery?
Interested in 1D and 1T...
I'll go with 1 daylight to experiment stuff
(+ eventually 1 variable depending on connector / dimmer availability)
Shipping to France. Thank you
2x variable 1x tungsten 1xdaylight but may change things around once I understand the accessories/dimmers ect.
