Mark Pedersen
- Aug 15, 2007
Anyone got a bead on extra batteries yet?
Rule of production: Backup!
M
M
M
M
Mine comes tomorrow too... :tongue: but .. did you buy one necessary tool for your Ronin ? :hurray:Mine comes tomorrow. Woo hoo!
Peter - I just put an Anton Bauer directly on the back of my Scarlet. Can I not continue to do this with the camera on the Ronin?
This will greatly depend on how big your battery is, how big is the mount at the back of your camera and what lens configuration and any other accessories you will need to attach to your camera.
The physical size of the Ronin limits what kind of configurations you can mount.
Basically with the standard arms you have 140 mm from the center of gravity of your camera setup to the back of the Ronin cradle.
You can test your setup by putting your (configured) camera on a pencil or some other tubular object to find the center of balance - then measure how much from there to the rear of the camera.
It needs to be 140 mm or less to even just fit - but you will still be limited in tilt angles. The more space you have at the rear - the more freedom you will have for tilt.
The idea is that your camera should be able to tilt down 90˚ and tilt up 45˚ without hitting the rear cradle.
But I have seen situations where +/- 30˚ is enough clearance for most situations - you just need to adjust your end-points and follow mode settings accordingly...
:sifone: Peter
Bought all I could get hold of but they available in Slovenia.
I don't have any "Plan" :smile5: I just connect D-tap cable I've got from E-bay directly into Blackmagic and it's work fine! :thumbup:Sergei,
Any plans on how you are going to power your BMPC on the Ronin yet or are you going to run off the short internal battery? Ronin is on the way (set to arrive on tuesday) and I'm still mulling over possible power options for my BMPC. I'm thinking top mounted 15mm rods leading to a V-mount battery on the back side of the camera but this would limit access to the touch screen.
What I'm PLANING to do, is to cut this cable and connect it to "right angled" connector to camera.. gonna do it right now :smile5:
I think this "small multi pin connector" is connector to HURO SENSOR, so I would not to touch it without asking DJI technician ... I power my Blackmagic because it's take very little for support internal camera battery, but for RED cameras Ronin battery DO NOT produce enough power, so just forget about it ... I was trying to place my Ronin on Steadicam Arm today:Some questions if any one is able to help. On Sergi's photo above in this thread there is a small multi pin connector visible. Its obviously a weak point. ingress for damp water fragile etc. Any one got any solutions for it ? Our plan may be is to encapsulate it with Hardman polyurethane which we hope will make it less vulnerable. All thoughts welcome on this. Also Does DJi make more of the top tube accessory mounts as an option or any one know where we cam purchase clamps that are the correct size. We aim to use Red Dragon on the rig and have flexible LCD cable to top arm and also flexible power in. The camera battery is intended to be mounted on operator belt but it may be we can access the onboard Ronin battery or strap another LiPo to the Ronin battery for camera power. Any one got any solutions for this please ? thanks,
Has anyone tried flying the Ronin yet?
Initial thoughts, worth it, not worth it?
Has anyone mounted it to anything but the handlebars so far?
thanks,
