Ivan Cortazar
I was having similar problems, and never was able to update it with Zterms. So I realized that you can update it with the Birger BEI software. I used the BEI at the end. I don't know if it helps. In the instructions it didn't say anything, or I didn't read anywhere that you could update it using the BEI software, which is so much better. I think I found it one day reading the forum. There is so much information scatter in this forum that it is getting hard to keep updated.
I hope it helps.
Ivan C.
I hope it helps.
Ivan C.
Hi all, have been trying to update the Impero firmware from v1.5 to v2.1 via ZTerm and the Birger mount. Two issues.
ZTerm seems to put all my commands and its replies on one line at the top of the window, overwriting the previous command or reply. Makes it difficult to see what's going on as a longer or multiline reply overwrites everything before, and short ones have the un-overwritten letters of the previous longer line still showing - don't know enough about Terminal use to know if this is a option preference I can change in the app.
Two, following the instructions in Birger's "Manually Updating Impero.pdf", I get to Step 8, and instead of "OK", I get an "Err12". I don't see "xe" as one of the commands in the Bootloader command list either - is there a typo?
"Err12" seems to be "XModem unlock code incorrect." Do I need to do an "xm" command - I used command "sn" to get a unlock code "0001-00117ger/viewfactor", do I have to enter all of that after the "xm" command?
