Roberto B
- Dec 31, 2006
a roma?
Hi all,
Ok... I just spent the last 3 hours searching for a way to get lens data to appear after changing a lens and without having to reboot the camera...
Is there really NO WAY to do this?
Will this problem ever be solved?
Can anyone advise me on this matter? How can any DP work that way? (having to reboot everytime he changes the lens, just to be able to check the iris...)
I wanted to share this Impero mounting solution which isn't the least expensive option but allows for quick switching between hand held and standard iris rod mounting. I used one 16x9 Cine Lock and one Element Technica 19mm Speedy Clamp. Even with the male part of the Cine Lock on the back of the Impero, it is still comfortable in hand. Check out the photos...
Hmmmm, it worked before for earlier builds. I upgraded to a newer build and had to roll back a build so that my lens data was visible. It is a bummer because I don't get to take advantage of some of the new build benifits. Maybe Red will be sure to include this in a future build?
but be aware this is non-approved connection of a 3rd party mount.
You can make a list of iris settings available for each lens when mounted on a Canon body, then when on the RED open up or close down fully and then count button clicks irising up and down. Not as good as lens data, but a solution of sorts.
I'm running camera firmware v21.4.1 with the latest Birger lens library (can't remember offhand) and the 3rd Party Protocol Support in the BEI Device Interface App are all checked, and I get lens data perfectly, even with lens changes, no reboot needed.
If I boot the camera without the mount or lens, I have to manually check the lens data in the camera menu, but that's it, it works from then on.
Are you sure this is a firmware issue on birger's part? If so, what's stoping Erik from solving it? Has anyone talked to him on the phone about that?
The only problem is that the s4/i option gets turned off, at times. I just need to turn it back on. No reboot. All is better!
