Matthew Quinn
I own an ikan rig like that.. The WC monitor cage is better for a few reasons, lots more mounting points, place for a vmount battery, and the cage is designed with 2 holes perfect for fitting onto a c-stand.
I was thinking of getting one of those cages and the new recorder from BM and use it with one of our bolt receivers. But on the last shoot I was on they got the new teradek cube.... well I think the days are very much counted for these little screen as the director was walking around with his own little Ipad and had the cube app installed... Doing frame grabs etc and emailing to the girl handling the shot list and so on... Well no matter what config you put on that cage, it will as it seams have a hard time to keep up with a normal iphone in the near future.
I know good recording, longer battery life, more robust and so on... but still every one has an Iphone and the new cube, in difference to the older versions, did not seem to lag or disconnect as they used to. I tested them a few years back to find them useless, today thats all very different, I can not understand why the are not commonly used.
Our bolt on the other hand also get some strange connection issue with dragon and when jumping between framerates and such... fiddling back and forth with the SDI output and rebooting camera usually makes it reconnect but some it really does not want to do what it´s supposed to.
Hi Bjorn, I don't much about the teradek cube and using these to monitor with to an ipad.
Can the iPad (iPhone, what ever) store the footage, or is it just a live feed only?
Ie, can a director what an iPad, then scroll back to the start of the take for instance- like you can do if using a odyssey 7Q ? and store that days footage on the iPad? (in a compressed format)
cheers paul
Still rocking my Radian with no issues.
http://www.bhphotovideo.com/c/produ...m11_radian_mc_tx_1_rx_multicast_wireless.html
These look great, do they cross convert? For example Hdmi into the transmitter and sdi out of the receiver?
Same here.
this is the one im looking at as well, just for basic needs. i like that its a small thumbnail hdmi, can you answer me though, you have to power each one from usb?
cell phone batteries???For the transmitter and receiver I'm using a ptap adapter. But you can use cell phone batteries too.
i se it comes with a usb connector on both, i think, right? which might be good if you have a jetpack.
where did you get the ptap cable?
Nick, how much range do you get on that thing? I'm so torn between a bolt 600 cinegears 300m and now this product you are showing looks really promising.. Any more info on this would be great, and yes I'm also selling a paralinx arrow + @@
You can get the 300m unit for much cheaper than the Cinegears price.... I've run 3 group buys for the unit through the manufacturer and it includes a free hard case. I recently ran a group buy for the 150m unit which Nick participated in.
