David Mullen ASC
Moderator
Red should make a camera for horror films called the REDRUM...
Perhaps it's a redux of the Scarlet using boards that were to slow for Epic. Perhaps RED (or their partner) is cutting 8K sensors for the VV Weapon and during QC they are discovering many of them have one or two bad photo sites. Rather than tossing them in the trash, perhaps they could cut them in half and put the good half into the Raven. This would be a roughly square, 4K by 4K sensor that would require roughly half the processing capacity of the 8K cut. The 4K vertical would be great for anamorphic capture and cine-photo applications.
Yes, after the Bayer pattern penalty it might not resolve a full 4K horizontal, but I'd expect it to measure out very similar to other nominally 4K cameras in it's market segment. If you absolutely have to have kitchen clean 4K then use a Weapon, Alexa65, 15 perf, etc...
I don't expect very high frame rates due to the demand that puts on the internal processing pipeline and read/reset properties of the Dragon tech.
I really like RED's designs, save for the R1. That's very wishy-washy, though its performance of course is terrific.I have to say that I have never been impressed with their design aesthetics.
Yep.Can't see RED abandoning S35, or releasing a camera that's only 4K. Doesn't seem in their DNA.
Shhh! Do you wanna get sued?!Red should make a camera for horror films called the REDRUM...
Actually... why not have high frame rates - but only at high compression ratios? That would be a good compromise between features, bandwidth and cost. Those who own the more expensive cameras won't worry too much, as they have higher frame rates again, plus they can use lower compression ratios.I don't expect very high frame rates due to the demand that puts on the internal processing pipeline and read/reset properties of the Dragon tech.
In time for Halloween. ;-)Whether it's a sensor or a camera, one thing I know is Red Raven is a great name!
Freya
