Exporting to DVD from Premiere pro- image quality is nowhere near 4k
Benjamin May
The file size is 336kb when I copy it to the DVD folder.
How do I export the 4K resolution to a DVD? I exported it as as an MPEG - 2 video. After exporting, the .m2v file I want to copy into the DVD is over 300mb- when I copy it to the dvd it is 336kb- thoughts?
Thanks,
One million questions here as to what you are trying to do and how you are doing, but the first question has to be:
Are you attempting to copy 4k content to a DVD? Or are you attempting to burn a playable DVD?
If the latter, keep in mind that DVD only playback in standard definition and will never playback 4k. Same for Blu-ray at the moment as 1080p is the max you can playback on that format currently.
If you are just trying to create a 4k video file to be played back on a computer at a later time I would suggest H.264 and pay close attention to your export and project resolution in the process.
You are very kind, Phil. ;-)
thanks Phil.
It is an 8 minute video I edited that I wish to burn to a playable DVD. I believe I did all of the preliminary steps correctly (importing red files, etc).
I would like to burn the highest quality (1080p i guess) to the DVD, which I don't think I am doing correctly.
export-> media
MPEG- 2 format'
max render quality
file size is about 500mb
I then hit export.
After that I find the file, copy it into the DVD, and it is about 350kb.
thanks Phil.
export-> media
MPEG- 2 format'
max render quality
I then hit export.
As Phil said, DVDs are standard def (720x480). The only way to burn a 1080p DVD is to burn a blu-ray. You can create an AVCHD through Compressor, which will make a pseudo-bluray for you, and that will be 1080.
Also, you may want to freshen up on how to properly author a DVD using Encore or DVD Studio Pro. Sounds like you're just dragging the video onto the disc, and that will never work.
Benjamin, you will never be able to playback a DVD at 1080 as it doesn't support it. This is why blu-ray was invented actually.
The maximum resolution you can ever hope to have on a DVD is: 720x480 (or 720x576 if you are a UK kinda guy).
Here is a lot of information:
http://en.wikipedia.org/wiki/DVD-Video
Sadly, even the best compressed DVD will never show the true quality or advantages of 4k.
Not to hijack the thread - but I've wondered if it's possible to burn 1080p material to a DVD (short-form, obviously) in codec/file structure required by blu-ray players...I used to do this all of the time with CD-Rs for DVD video when I was in school. Anyone know about this?
Thank you for chiming in so quickly.
Obviously I had no idea what I was doing- but at least I know that now!
Ben
That's what I was just talking about. Google AVCHD-DVDs and Compressor. You can burn Blu-rays on a normal DVD assuming it's a short project. I think you can fit like 30 minutes...
Awesome, thanks! I'll check it out - got a couple 10-15 minute things I'd like to not have to buy a blu-ray burner for...
You can use the roxio toast 11 pro for this and for me it works faster and better than compressor. With better I mean I had less issue playing it back on a stand alone bd player. Im not sure you can import your own menus.
Using Roxio I found that DVD media tends to bring the quality down almost to a third of what you think it should burn.
Basically the software sees the media and recodes it to crap.
Stick with BD discs no matter what.
I wouldnt spend $$ on R3d to HD based DVD authoring for anything, not even your kids dance recital :P
