Brian F Kobylarz
A deluxe starter pack could have OMOD, OMOD video tx, Paralinx or Teradek Rx, handset, motor, cable, and a latitude MdR for use on non-WPN cameras.
Why specify non-WPN cameras?
I would love to see a bundle with an Omod, an Rtmotion handset, and an Rtmotion motor and cable.
maybe call it the "Starter Pack"
Bundles should be up by the end of next week.
Hey Mark, these all look great. Any plans to build a more basic module with multiple, separately assignable, SDI outputs? I'd love to be able to send separate looks out to a village monitor, DP/operator monitor and an AC monitor. Don't need a lot of the other bells and whistles.
Hey Mark, I hope you are doing great. I bet you're not getting a lot of sleep at the moment.
It would be awesome to have you or one of your team and the RT motion folks do a video, or at NAB do a presentation or have some time in the RED booth or whatever so we can puzzle through the options. I'm fine waiting a bit and using my existing bundled and third party solution until mid April if necessary. There are a lot of great options here, and it's easy to miss something. As an example I didn't know until tonight that Weapon/Abox can't do phantom power like they did on Epic. It's those little gotchas that I'm looking to avoid.
Congrats on all the great work.
Steve
Is there no version with 4k output?
The HDSDI outputs are just 1.5gbs? 10bit 1080P 422 max?
How can the listed HDR/2084 monitoring work?
Is the second EVF/LCD output on the Weapon brain disabled when using an Omod?
It is a combination of the Color Space: BT.2020 & Gamma: Log3G12 and a high precision 3D LUT
OK, but how could you monitor that with just 1080p SDI output?
Unless there has been a change the BVM-X300 needs UHD/4k quad-link SDI to enable HDR gamma mode.
Any consumer HDR monitor needs UHD over hdmi 2.0 with the HDR flags enabled to activate HDR mode.
The OMOD 4k Pro is canceled or just postponed?
Christopher*Seguine said:OK, but how could you monitor that with just 1080p SDI output?
Christopher*Seguine said:Any consumer HDR monitor needs UHD over hdmi 2.0 with the HDR flags enabled to activate HDR mode.
Nobody monitors on set with a consumer display.
I never announced any 4K OMOD. But, if it ever becomes possible ... I will certainly do it.
First up is OFFHOLLYWOOD's OMOD MINI, OMOD LT, and OMOD 4K PRO come see Mark and working prototypes on Weapon in our booth tomorrow.
HDR is not tied to resolution. The X300 has a user menu option to select ST2084 as the transfer function. Same for the Dolby Pulsar.
Again, not true at all. Even Sony's consumer displays have a user HDR on/off option. I have tested with both 1080p and 2160p HDR content. I know one studio planning to release HDR as 1080p instead of scaling it up and lying to customers. I have been using a QuantumData 780 generator signaling the CEA 861.3 metadata over HDMI into the Samsung and LGs w/o any problem. They all correctly go into HDR mode at 1080p. And FYI, this was with HDMI 1.4 transmitter. It is easy enough to create a generic InfoFrame over HDMI. Dolby Vision does not even use the InfoFrame.
Christopher*Seguine said:The last time I tried regular hdsdi with the X300 it did not allow selecting any of the slog3/2084 HDR gamma modes in the EOTF menu, I see the updated manual indicates it is a selectable option for 2k sources. Have you tried it?
[/COLOR]Both need to be 2020, which I found to be odd, but no issues with 1080p HDR.[/COLOR]
