Kaku Ito
- Feb 20, 2008
- Age
- 65
- Chiyoda-ku, Tokyo
- www.dittok.info
Also, when will ME support Red Rocket rendering?
Craig,
ME's black and white points are set from 0 to 100. Is there a plan in the future that will be changed to 0 to 1023?
Hi Kaku
There are no plans for this.
The 0 to 100 is floating point though so you can just convert your numbers to percentage (i.e. you can use 29.297 where you'd otherwise use 300) and you'll get the same effect. There is no loss of precision.
Cheers
Craig
I asked because when I tried to input with decimals it didn't seem to accept it but I will try again. Thanks.
Craig,
I'm curious as to wether or not Monkey will add RED Rocket™ support?
Just checked. You are quite right.
That looks like a bug. I'll need to get that patched up.
Craig
RED Rocket™ support is definitely coming.
I haven't got an ETA for you yet though.
Cheers
Craig
Hey monkey boys! I used a demo of your software early on to batch generate new/replace proxies for a reel of r3d's with a new grade on it. Is this still possible?
I forgot how I did it but was amazed when it worked. This was like a year ago...
what up? amd thanks.
j![]()
any word on when ME will support the footage coming from the MX sensors, with all the noise-reduction improvements that go along with full support of this?
i know any ol' application that works with .r3d's can deal with the new files, but they don't process out/take advantage of...the new science, and the files come out looking like they were shot on old reds.
Craig??
Hi there
Great app. Experimenting with your trial version 3.100. I am trying to send a sequence of shots to RedCine. It tells me to 1. Open RedCine 2. Select "Project, New..." 3. "Import....
I am using Build 44 of Red Cine. Are you referring to an earlier vers/build to do this? I am not seeing a "Project, New..." option on my current version. Which version should I get if it is a different one?
Hi, I rendered in rocketcine-x utilising the FLUT™ control and wanted to do the final conform in monkey extract but the colour is all wrong - I can only assume that there is rsx info that monkey extract can't read properly? Is there anyway around this? It'd be a real shame to not be able to use these new tools in rocketcine..
Hello
I'm trying to get a DPX sequence out of a FCP XML using Monkey Extract
Everything works fine expect the DPX doesn't carry the "look" i've set in camera.
When you use REDrushes, it gives you the option to set LOOK SOURCE > Camera..
How do I achieve that in Monkey Extract
My settings are:
- Use metadata from each shot
- don't use RSX settings
Footage Color Space: Camera RGB (i've also tried Use settings above and didn't work either)
any ideas.
Thanks for your time.
Best -
alex
