John Marchant
- May 4, 2010
- Normandy, England
- www.kippertie.com
Hey Mark. Its probably too long a post for now, as I should be wrapping for the day... essentially though, all cameras will have a noise floor, and all humans will have a tolerance for that noise in the image. The picture is everything above the noise floor, so it makes simple logical sense to test camera systems for comparative dynamic range by benchmarking a visually acceptable noise floor and judging what lies above it on that basis.
Every manufacturer's implementation of ISO varies, and testing at identical practical settings of lens / software setup may hamper or advantage any given system.
My suggestion is that to compare two cameras for dynamic range, the most illustrative starting point is the one where the shadow noise is most visually comparable in motion. If one camera is cleaner than another, it implies that the chosen ISO, mid gray, gamma curve, or whatever other developmental implementation is used is comparatively biased towards shadow. If the two cameras were otherwise identical, the one with cleaner shadow would consequently have to show less highlight range.
When you then conceptually write off the shadow difference, you draw a false conclusion about the highlights.
