Nick, is there any indication of timing? We are close to a year now on this GB thread.
Looking forward to a massive discount considering the USD is 20% higher vs EUR than when the thread started.
What is the status on availability and price?
Here's the skinny to date:
A supplier of a tricky part is still working on getting it right and consistent. If he gets there quickly, yes, 6-8 weeks. If he doesn't... need another try. It's a pain, but there will be no technical compromise accepted.
As for missed box rental, if you absolutely NEED to own a follow-focus right now, then best to just go for one of those other fine products available. The worst that can happen is that you end up with regrets once you see the Revolvrs, right?
Hi JIm,
I am very concerned about gear ratios. As some of my lenses have 300mm rotations, as it stands right now for instance I need a 64 tooth/0.8 gear to work with your LFF-1. As I need small and light, what provision do you have for the Atom version to deal with this kind of situation? Otherwise, I fear having to go beyond one rotation of a handwheel for my marks. Will you have gears to deal with this? Arri compatible otherwise?....
