- Thread starter
- #181
Mikael Lubtchansky
- Jul 31, 2007
- France
- www.foolcolor.net
Hi Mikael,
Your foolcat-app works flawlessly with about everything I have shot but my old RED ONE-files from 2008-2012. I don't know if I am alone having this problem but if there is a solution it would be much appreciated.
When I load an old RED ONE-mag folder in the source directory, foolcat recognizes the correct number of individual R3D-clips in that folder. But when I click ”Create catalog” the app never gets pass creating thumbnails for R3D clip 1/xxx. Foolcat neither freezes nor crashes. It just sits there, so to say. A main foolcat cataloge folder is created but no files are generated inside it.
It would be great to have foolcat work on my early RED work. (The app does support older R3Ds, as I understood it.)
DETAILS
I’ve tried the following things on both a high end iMac 5K 2017, a MBP 15" 2013 and MBP 17” 2011, all with the latest MacOS and software, but the end result is the same:
1) Trashing the latest versions of foolcat and RCX-PRO plus preference files and reinstalling everything including the RED Apple workflow plugin.
2) Ran Disk utility.
3) Source directory in foolcat has been set to the original RED MAG-folder that was processed with the Redcine dating back to when it was originally shot (2008-2012). I tried both with the old QT-proxies present in the .RDC-folder and without them.
4) Source directory set to a duplicate RED MAG-folder processed with the latest RCXP 42 as well as the latest beta version of RCXP 50. Created new RMD-files each time.
5) Tried source directory set to either a) the RED MAG-folder, b) the .RDM-folder or c) the individual .RDC-folder.
6) Cleaned in and out set points of individual files.
7) Created new (RED ONE) R3D-files using RED TRIM in RCX-PRO.
As I said, foolcat has no problem generating catalogs for EPIC and EPIC-DRAGON or any QT-files I throw at it.
Thanks for a super app!
PS: Any chance you can update foolcat to create larger / higher resolution jpgs in the foolcat_files-folder? And while we’re at it, perhaps an option for increasing the number of jpg thumbnails generated for each clip?![]()
strange it does not work as I often test with old clips dating back to early R1 days.
Maybe an issue with file path or something as I just verified RED ONE still works here.
please email me so we can look into this... mika at foolcolor dot net
as for larger files and more thumbnails per cli, both are planned future features ;-)
