Andreas Kielb
Dobrej den Ostraváku! (I used to live in Novy Jičín / Šenov when I was a kid...)
As Constantine pointed out (thank you Constantine!) - we have discussed this over the last few pages in great detail.
THIS is the key difference between Steadicam and Gimbals, exaggerated by the fact that this was my first test with the Ronin.
I know then more I will work with the Ronin - the better I will get at managing this issue.
This has nothing to do with the Ronin - this is 100% issue with the motion platform - in this case human operator - myself...
:sifone: Peter
Very nice footage, Peter! The footsteps issue can easily be solved by attaching the gimbal to the steadicam sled. Since you also work as steadicam operator it would be great if you could include that into your tests. What I really like about the Ronin is the possibility to tune the system automatically, at least if that works reliable for different camera setups and weights. Did you use the autotune option to setup the Ronin for the shots in your video? Maybe you also could try the autotune with much lighter cameras like a DSLR to see if it works constantly good?
