- Thread starter
- #161
Peter Majtan
- Feb 29, 2008
- Tokyo, Japan
- www.petermajtan.com
Peter, how do you power your Paralinx transmitters/receivers?
I forgot to add the most important aspect of this - the Ronin itself includes 2x D-tap and 1x USB power connectors on the base of the camera plate.
The PARALINX ARROW and ARROW+ needs USB power - so you can just plug thin short USB cable to the Ronin's base and power up your transmitter.
The ARROW-X and TOMAHAWK come with standard D-tap power cables - so you can power them as well directly from the Ronin's battery via the camera base.
This is more then you will need to power any accessories on the gimbal itself...
The LiPo solution I have posted above is for the receivers on the handle-bar (and by the client's monitor).
I have chosen LiPo's for my own personal reasons - but here again PARALINX provides various options for powering the receivers.
From standard main-powered power supplies, through custom V-lock / AB plates and a plethora of various cables to plug into the 2-pin micro LEMO on the ARROW-X / TOMAHAWK systems.
If you need something custom - just ask PARALINX - they can make pretty much any cable you can think of...
:sifone: Peter
From the new DJI RONIN page...:
POWER DISTRIBUTION BOX
"Two regulated 12V P-taps, one 500mAH full size USB connector, and also a connection point for the DJI Lightbridge Long Range HD Video Downlink are provided. This offers convenient power connection for various accessories including follow focus systems, HD video downlinks and others, all while keeping the wiring to a minimum."
http://www.dji.com/product/ronin
