Paul Cronin
I agree with Michael. With out the work of Erik and Curt bringing this solution I would not have purchased the Red One.
:shiftyph34r:
On another note...
What are you using for a monitor in the video?
I think I have space to go lower in the collimating ring and make the 17-35mm work, that would make my main lens (28-70) don't hold focus.
The monitor I used is:
HP-W2408H for $350.00
I'm told a better alternative is:
Dell 2407WFP-HC
I've been using my Birger Mount for a while. I collimated my mount without any problem and I did it with my 28-70mm. It holds focus and it works perfect.
I also have a 17-35mm. In that one, It doesn;t hold focus and recently I discovered that I can't focus past 3 meters (I don't use that lens often, and when I do, it's in small rooms, so I didn't realize the focus issues).
Joel do you find the 17-35 EF-S lens are up to the quality of the EF-L full frame lens?
The collimation adapter on early units is too long,
Maybe I'm misunderstanding, but I've removed the screw in ring entirely and still can't get my 11mm collimated. That implies to me the original mount is a tiny bit too thick.
Ivan I think you mean the 16-35mm EF L lens or 17-40. When I was doing this with Erik we dialed it in with my 16-35mm lens. On expanded focus is it perfect from 35 to 16? I have found that it needs to be perfect for my other lens to work well.
Ivan, you will get an email from us shortly regarding your upgrade.
Also, always collimate with your shortest, fastest zoom.
Minor changes were made to both parts, to ensure proper collimation could be reached on all cameras.
...Sorry for my ignorance but if now I have my longer lens (28-70mm) with the Birger mount and holds focus (collimation ring 4.5), if I switch to my shorter, and do the collimation again, and make that one hold focus, is it possible to make both the shorter and the longer hold focus at the same time? Even if the new collimation is, lets say 2.5?
I don't know about optics, but my thought was, If I found the sweet spot for the 28-70mm, and another lens needs different distance, that would mean that I phisicaly need to adjust-collimate that shorter lens to match the 28-70 and not the Birger mount. I don't know if I am explaining it clear.
Thanks,
Ivan
I thought the collimation would be needed only between different mounts, not lenses. Isn't that so?Sorry for my ignorance but if now I have my longer lens (28-70mm) with the Birger mount and holds focus (collimation ring 4.5), if I switch to my shorter, and do the collimation again, and make that one hold focus, is it possible to make both the shorter and the longer hold focus at the same time? Even if the new collimation is, lets say 2.5?
Thanks,
Ivan
Ivan, you will get an email from us shortly regarding your upgrade. The collimation adapter on early units is too long, because of a lip on the camera. We are replacing this for everybody when their Imperos come available. Sounds like yours is one of the affected mount/camera pairs.
