Patrik Kisucky
Let's dooo THIS.
Just did some very very brief tests. I noticed on the power menu that it now also seems to tell you the minutes remaining as well as percentage, which is fantastic.
For those curious, the 1K resolutions read in Premiere Pro as:
1K WS = 1280x480 (Max FPS seems to be 120fps)
1K HD = 1280x720 (Max FPS seems to be 89fps)
This is a great update.
I can't wait for the first My Scarlet and Mic Exploded :'( thread!
Will there be a wall of shame sticky?
Updated EPIC-X #2229 from last 3.x build... oooops
Support ticket time. Log saved. Anyone else seen anything weird? This update was done as per the book, no side handle. Going to try rollback to production build.
Mike
Just did a test as well, 120 FPS looks glorious!!!
I had an issue updating as well, came out with color bars on my Scarlet and wouldn't let me re-upgrade properly. Also limited 4K to 8 and 12FPS which was weird, as that is obviously a 5K thing....I just went back to the default factory settings in the menu, and that cleared everything up. Strange, but whatever works!!!
OK I reproduced it. Installed production 3.0.7, everything was fine. Phew! Re-installed 3.2.8 - colour bars again. Did a default reset, works fine with 3.2.8 now.
Suggest the factory reset needs to be documented in release notes!
Mike
