- Thread starter
- #501
- Aug 9, 2011
"Filmbias" is indeed interesting Rand. Eventhoug it appears it reduces color response in the magenta green axis. Yellow is the problematic color IMHO when using RED.
When using Red pictures I think using the color sapce transform in the lut (put at the end of the nodes) holds the best result. So strating with RWG Log3G10 instead of Rec709 BT1886
I didn't understand your statement/ question , could you be more specific? And you can correct a yellow issue in any image with a simple" HUE SHIFT", if you don't use "Tint" to correct the RED image, or "PRINTER LIGHTS" YELLOW reduction.
EDIT:
I think due to the Spectral Locus that the RED KOMODO uses in relation to past Red Cameras, you "CAN" use "Tint" and a "HUE SHIFT" to get better results. In the Past it was Either/Or.
