francisco santos
- Jul 16, 2012
- BOSTON/NYC/LA
- www.superiormediagroup.net
i use my glidecam 4000hd works perfect!
I might end up trying the Chinese vest, for that price really doesn't hurt.
I sold my Pilot b/c its weight threshold is too low for the Scarlet/Epic.. It's for DSLR
The one thing about being in the middle of China is I get to check out a lot of these brands. Bought some 800W redheads and LED's.
Dude the pilot is rocking the Scarlet totally fine if you don't overload it.
If you strip the scarlet to its essentials, and use a lighter lens, you are fine.
Max payload for Pilot is 10 lbs, Scarlet is 5 lbs. So any lens that does not go over 5 lbs is fine.
You just need to re-wire the pole if you want to use hd-sdi and an HD screen.
http://www.reduser.net/forum/showthread.php?70147-Post-Your-Scarlet-X-Rig&p=1070668#post1070668
Abraham, are you saying it's ~$320 for the sled and 7000yuan for the vest/arm? That's like ~$1100+300 for a 15kg set up... how much is shipping?
Ah, therein lies the rub! Like I said, it's an advantage to be on the ground here, because of the shipping costs. I would try to talk them into the slowest, cheapest shipping possible and then see if it's worth it. They are very cool so just email them and see what they offer info@wondlan.net.
Got any results? Pics of the rig is great, but how does it fly? Can we see?
Thanks for posting, looks goodFlies like a brick. ; )
Here is some snippets from a run and gun behind the scenes shoot:
https://vimeo.com/56233196
(NOTE: link will be up for a short time only as the footage is from a unreleased piece)
PASS: reduser2012
I have to add that I am a really crapy steadicam operator.
Things to keep in mind is steadicam is a brand name product that you can always sell.
Where no name products are impossible to sell used.
I know of two people that sold there old pilots for 2,8k - 3k as they upgraded to bigger steadicam rigs.
Cheers. ///
Dude, I'm convinced... Awesome!Here's my first real test with the Chinese Steadycam. Mind you, I am not an experienced operator, I was also walking on soft sand and in high winds. This was also my first go at it. I think the rig is solid. I'm sure with practice I can get better results, but for my first go at it I can't complain.
http://www.youtube.com/watch?v=Gdsg11gxcLk&feature=youtu.be
Never seen this unit in person so it's impossible to say how well it performs. The two critical components of a stabilizer are the gimbal and the arm, as they directly affect the isolation and smoothness of the system. Outside of that, the rest of the sled needs to be rigid to avoid vibrations and remain balanced once set (and be easy to make adjustments as needed). A few things to note: the design is more a knockoff of Glidecam than Steadicam. Even the entry-level Pilot has passthrough power and video through the post, which this does not. All cables from the bottom to top of the sled will have to be strung externally with this system.
The price is certainly eye-poppingly low, considering the design. Knockoffs have gotten quite a bit more sophisticated. Still, there are certain things that indicate the level of understanding of what it means to actually operate a rig that are missing. Not including a docking bracket is a strange choice. You need to be able to dock the rig safely and securely between takes.
For the record, the Steadicam brand rigs for small cameras stand alone for a few reasons, not just relating to the brand name. The arm performance is better than any of the knockoffs by a significant amount. And that will directly effect the final results. If one is not particularly picky about the final results, I'm sure this would function fine.
I think for $1300 it's safe to say I'm not concerened about the resale value of my stabilizer.
That's good about the docking bracket. It wasn't listed in the "included items" nor shown in the pictures--although there seems to have been a few links posted in this thread so maybe I was looking at the wrong one!
Good to hear you can feed cables through the center. That will actually be better for many people, such as those who use cameras and monitors that require HDMI for instance.
I don't really keep up on the rigs much any more but it's interesting to see how these cheaper ones are getting more sophisticated.
As always--getting the gear is just the first step. The skill remains the same, and takes a LOT of practice!
