Martin H Ahlgren
- Mar 13, 2018
I've just put abbreviation for focal length.
This is the effect we all know, a combination of focal length, distance and format crop:
The video here is the best one I've seen to demonstrate how focal length works. (Did you shoot it Hrvoje?) Usually they are never done with the exact same field of view, but when done right, like here, you can truly see that a longer focal length does NOT have shallower focus. This is an argument I have with directors all the time. Going on a longer focal length does not yield a shallower depth of field if the field of view stays the same. The two things determining depth of field is sensor/film size and aperture. The background might at first appear more shallow on the longer lens due to the magnification of that part of the image, but if you look carefully in a clip like the one here, you see that the amount of blur in the background is consistent between the widest lens and the longest one. On the longer one we just see it larger.
This is probably obvious to all readers here, but even many seasoned filmmakers still won't believe it! It's all those crappy photography course books, claiming you should use a telephoto lens for shallow focus, showing photos with wildly different field of views to demonstrate depth of field, that have confused us all. Alternatively in tabletop, it's often suggested to go to a wider lens for more focus when it's too shallow, but as you move the camera closer to get the same size on the new lens you slowly realize that you're chasing your own tail...
Martin
