Giles Harvey
- Nov 4, 2009
- OxfordShire
- www.luttrellproductions.tv
RF - EF canon approved adapter with VND on canon 70-200mm around 135mm low level winter sun
Does the Canon R5 or other full frame mirrorless or DSLR cameras use split sensors on their full frame cameras?
As a owner of a Raptor (and Monstro).. The question of if other cameras have a split in the sensor is purely academic and not very helpful (don't get me wrong I am interested but it is not actually helpful) ...
The only question that matters is... is there a split in the image using a real lens and in a situation that may actually happen for us?
I have seen myself that this is possible... and even though it is unlikely I don't want to have to shoot around it.
I also have had solid feedback from a mate that he has seen the split with more than one RF lenses (which I can double check if needed) so the lens mount debate seems slightly obfuscating! I believe it is a internal reflection issue that is mitigated against on Monstro due to the position of the IR/UV optical stack. I think this because I have shot Monstro and Raptor in identical flare situations and Monstro is slightly more flarey SO I don't feel it can just be that Monstro has simply a better intrinsic flare guard! I have checked my Monstro with different OLPF and I can't produce the split so the fact that there is one is irrelevant!
Hopefully there is a 'flare guard' type solution. One that doesn't narrow things to the point of causing issues with other types of lenses.. Some of us remember having to 'flock' our Epics before Reds flare guard solution! If I don't hear from Red officially I will look at some Diy solutions to see how viable a flocking solution is ( I am slightly worried about messing up the edge bokah on some lenses..as Raptor is a big chip... but it is worth investigating.
Can't believe the split sensor happens with native RF lenses. I was about to pull the trigger on Raptor but this is a deal breaker. It's so annoying but the camera doesn't seem reliable at this stage.
...update on my end, my V-Raptor is being called back in by Red to investigate the sensor issue.
I actually haven’t sent mine in yet due to work and now holidays. Also, I’m not sure if there’s a fix so it would just sit at the bench I’d assume.
Product Management
December 08, 2021 14:01
RED takes all customer feedback seriously and is looking into sample images that have recently been shared online. The few images we have seen until now appear to have an artifact during a very rare combination of scene lighting and lens setting that has not been visible with most customers or shooting conditions.
An internal assessment has confirmed that the sensor is functioning as designed and performs above expectations with image quality. The artifact that was shared online has instead been verified to arise from internal reflections during uncommon shooting conditions. The team is now working on a solution for those select customers and will come back with more updates as soon as possible.
Interesting, I’d imagine they would work on a solution for all customers. I’m trying to stay as balanced as possible with this whole situation, but it is happening with lenses under flared situations regardless of mount. I understand some people wont see it on a lot of stuff, but one day you might, it could be a bad take or it could be something important. Unfortunate to see this position, very “you’re holding it wrong.” - Steve Jobs with the antenna problem.
