Martin Stevens
REDuser Sponsor
In regards to Macro lenses, I love my Canon 100mm f2.8 L Macro lens.
Very nice for portrait work, as well as macro work.
That's why you can't buy lens's on ebay .... they are the rejects from guys like Ketch !![]()
Same thing with Cine lenses, you need to calibrate them, and makes sure that the back focus is set properly on the camera, and not touched.
Martin, use the widest, fatest lens you have and set the sensor plane on a tripod at a marked distance from a focus chart. Use the 1:1 mode and either the focus or outline modes to help you determine if the image is sharp at the marked distance (6 feet is a good staring place). If your three widest lenses tape out correct you're probably good. If you have a zoom you'll notice that the focus will not hold through the range if the backfocus is out. Unless of course it's a still lens and then it just may not be parfocal.
I always wonder why anybody would use a macro lens designed for, uh, macro photography and optimized for close up work for normal distances. There are lenses designed for normal work....:wink5:
And BTW I know how these lenses look -I've projected lenses for 25 years- it's my business....
Setting the backfocus on a lens needs to be done at an optical facility or a camera house with a lens collimator.
I understand that this might be the BEST way to do it, but I assume that it is not the only way.
No, it's the only way. Certainly one can work his or her way to a somewhat correct backfocus on the camera using a properly set lens. But there is no way to collimate a lens itself without the correct tools. A collimator costs many tens of thousands of dollars and the precision shims used to set the mount are measured in microns.
Really like my Duclos Cine-mods ZFs and his 11-16mm here!
