Alvise Tedesco
V-lock only or AB as well? Don't remember
Nice and light! Anton Bauer??????Just saw on facebook that these will be out next friday.
47WH 0.80LBS $250 for one or $225 each for a 3 pack.. no accompanying charger has been designed, just use whatever v-mount charger you already have.
Also saw that the new V-Mount module has power lemo port for the camera / charging.
Anton? Where did you see the new V-mount module? Are there more photos and details posted anywhere?
A Power Question - Power Cubes -
Has anyone ever wondered why someone hasn't made battery modules with front and back connectors without a specific mount? It's a little "Cube" of power. 45WH per cube. You want 90WH, screw two together. Want 135WH, screw a third one onto the first two. 180... yep, put four together.
And then, there are three or four little metal plates with the mounts - that makes the batteries what ever you want or need on the day - V-Mount, Gold, Redvolt, Tap.
Maybe there's a thin cover to seal up the front connector and maybe make them water resistant - and cool looking.
You could even make a product to jump start cars - mass produce them - and make them even more inexpensive.
I mean, if this kind of connection works on the RED monitor connectors, why wouldn't it work on batteries?
Maybe I should go patent this?![]()
-Glen
