Gunleik Groven
REDuser Sponsor
David, I guess you're forgetting the broadcast module...
So will 3d LUTs be able to load into cam or no? Not clear yet?
Totally,
it will come down to who wants to be informed and how it can be implemented. All we can ask for are the tools.
battistella
Stop worrying and love the 3D LUT. It will set you free.
David -
The thing about 3D LUTs is that you have to power to effect colors in a very, very high fidelity way. You can map any specific color value to a different value - or a range of values to a different range of values. You can emulate a specific film stock in a very organic, subtle way that could never even be approached with a CDL or even an RMD.
It's not some "dark art" reserved for super geeks and DITs only.
Yes - for years big post production facilities would bullshit their clients that only they had the "magic LUT" to make the clients DI look correct, etc. etc. bla bla bla - but now most good DITs have more knowledge of modern workflows than employees of large post facilities. That is a fact.
A 3D LUT is big spreadsheet. THIS exact value in = THIS exact value out.
There are more 3D LUT creation and editing tools coming to market that make it easy to create and edit 3D LUTs.
And there's TONS of crazy creative things you can do beyond emulating a celluloid film stock - as you can target and effect specific ranges of color values - like ... skintones
It's happening now.
It's not just about display luts and signal path workflows and color space transforms. That is the obvious. But that only scratches the surface of the power of 3D LUTs.
3D LUTs are a SERIOUS creative tool.
Mark my works - they will become very commonplace very soon.
Not clear yet. Also not clear if we can get different/independent gammas applied to SDI and EVF/LCD outputs.
We will have to wait for details - but no matter those details are - it's fantastic that ACES is done and solid and RED is clearly moving in the right directions.
I'm stoked.
So conceivably, for anything (other than a live feed) that needed editing, an editor would be all you'd need?Luts are to color correct as pre-vis(ualtion) is to post-SFX
Part of it is getting rid of dailies and letting you see color corrected the image on set.
Part of it live broadcast of multiple cameras.
Part of it is seeing a color effect on set and being able to light for that effect.
I would re-ask for a linear in-camera signal again, if this come true.
This is possible with a hack. I used this on the Dynamic Range testing with Stacey and it now lives on my Epic.
1) Enable linear in REDCineX
2) Save a look with linear gamma to the SSD.
3) Load the look into your camera.
4) Create a new preset that only affects Gamma and load the Linear Look.
5) Assign the Linear Preset to a button or hotkey.
6) Linear output!
