Bob Zelin
- May 31, 2009
- Orlando, FL.
- www.bobzelin.com
Hi Joel -
you are a RED camera owner. You own expensive computers. The QNAP is the least expensive item of your equipment.
The TVS-1282T3 (if that is what you are buying) comes FOR FREE with a dual port 10GbaseT card, so you do not need to buy anything else. Please be advised that the wonderful TS-1685 is a 12 bay for the same money (you need 4 more drives) but also
comes with the free dual port 10GbaseT card. The QNAP is a network attached shared storage system. It is not converting anything for you. Your transcoding is done from programs like RedCine-X or Edit Ready, or Adobe Media Encoder or Apple Compressor.
The QNAP is not a render farm. It's a shared storage server.
You can get the TVS-1282T3 with 32 Gig or 16 gig of RAM. This will cost you about $3000 US. You can get the TS-1685 for the same money, which is a 12 bay. Both models have dual 10GbaseT ports, so you do not need a switch for your computers.
To get 10G speeds, you need a 10G Nic, or a 10G thunderbolt to Ethernet adaptor from Promise or Sonnet, unless you have the new iMac Pro which comes standard with a 10G port.
The TVS-871T will work fine for you. Again - it's just a couple of hundred dollars less. I have never seen a TVS-871T for less than $2600, and the TS-1685 is just under $3000, so for $400 more, you get a more powerful 12 bay.
All these models have built in dual port 10G ports.
These are all great products, and editing in 6K and 8K will be no issue for you. Of course, if you only have a 1G connection to the QNAP, you will not exceed 100 MB/sec, so your hidden cost is the 10G adaptor for your computer. And no, Thunderbolt
won't accomplish what you want. You need the 10G adaptor.
Bob Zelin
Bob Zelin
