- Admin
- #1
- Dec 27, 2006
OFFHOLLYWOOD is about to release 3 incredibly cool products at IBC, The HotBox, HotLink, and the HotTap. Mark has been kind enough to let me give you guys a sneak peak.
The HotBox and HotLink take advantage of the RCP protocol we released at NAB for wireless camera control, and when paired with the mighty FOOLCONTROL app, it is insanely cool.
The Hot Tap is a P-Tap splitter that gives you 4 wonderfull P-Taps so you can now blow up 4 of your devices all at the same time instead of just blowing up one.
OFFHOLLYWOOD will also be in our RED booth @ IBC with all of these on cameras... you really need to touch and play with these things. Great manufacturing and all made in the USA.
You can order all these bits now and they look to be shipping early October. http://offhollywoodny.com/store/
RED DRAGON + OFFHOLLYWOOD HOTLINK + FOOLCONTROL
HOTBOX R/S WiFi
The HotBox R/S WiFi is a next-gen, bullet-proof power distribution box (aka "splitter box") with advanced, multi-protocol run/stop functionality designed specifically for rental houses. It is the same product as the HOTBOX R/S with the addition of an internal HOTLINK module to allow for WiFi control of RED DSMC cameras.
Featuring:
WiFi control to RED DSMC cameras (Scarlet, Epic, Dragon). The DSMC Serial Cable (included) connects to the CTRL port on DSMC camera (4-pin 00 LEMO) to the HOTLINK serial input (4-pin 0B LEMO) to pass RS232 communication over WIFi - allowing any application - such as FOOLCONTROL - that supports RED's RCP Protocol - to remotely control and monitor the camera and read/write meta-data to/from the camera.
2-pin LEMO power input receptacle that features directional over-current protection preventing current from ever flowing back into the power source.
4 x precision crafted female P-Tap power outputs from the HOTTAP
2 x 2-pin LEMO power outputs
3-pin Fischer power output + Run/Stop
4-pin LEMO power output + Run/Stop
External fuse for fast access on the set
Timecode input for RED DSMC cameras via 5-pin LEMO
*HOTBOX WIFI ORDERS BEGIN SHIPPING end of October - first come, first served.
MADE IN NYC
- See more at: http://offhollywoodny.com/store/hotbox/hotbox-rs-wifi/#sthash.zdPfs5Mu.dpuf
HOTLINK w/DSMC Serial Cable
The HOTLINK adds WiFi control to RED DSMC cameras (Scarlet, Epic, Dragon). The DSMC Serial Cable (included) connects to the CTRL port on DSMC camera (4-pin 00 LEMO) to the HOTLINK serial input (4-pin 0B LEMO) to pass RS232 communication over WIFi - allowing any application - such as FOOLCONTROL - that supportsRED's RCP Protocol - to remotely control and monitor the camera and read/write meta-data to/from the camera.
Wirelessly monitor the histogram & goal posts, start/stop the camera in addition to changing any setting - instantly - from 60+ feet away from the camera.
Power the HOTLINK via a 2-pin LEMO power input OR a USB Mini power input - perfect for shooting on gimbals and drones.
A captive 1/4"-20 screw for fast, easy mounting on cheeseplates, sidearms, top plates and handles.
Connect via AP (access point) mode for a secure, direct connection to the HOTLINK - OR - connect the HOTLINK (or many HOTLINKs) to a router (STA mode) - allowing a single iOS or Android device to control multiple cameras with HOTLINKs.
Configuration is fast and easy via a simple, embedded HTML interface.
Low Power Consumption (Normal (Ave): ~12mA ; Peak 200mA; <200uA Standby)
Temperature Range:
Operation: -40ºC to 85ºC (-40ºF to 185ºF)
Storage: -40ºC to 125ºC (-40º to 257ºF)
Certifications: FCC, CE
Frequency Band: 2.4 GHz
Security/Protection:
Encryption: WEP64/WEP128/TKIP/AES
Security: WEP/WAP-PSK/WAP2-PSK
*ORDERS BEGIN SHIPPING the Week of October 6th - first come, first served.
MADE IN NYC
- See more at: http://offhollywoodny.com/store/hotlink/hotlink/#sthash.5KjmOKHn.dpuf
HOTTAP
The HotTap is a next-gen, bullet-proof P-Tap splitter crafted from precision CNC'd aluminum and DuPont™ Delrin®.
An internal, resettable fuse protects from accidental overload.
The 2-pin LEMO power input receptacle features directional over-current protection preventing current from ever flowing back into the power source.
Use a 2-Pin LEMO to P-Tap power cable to power from a battery plate or battery, or a 2-pin LEMO to 2-pin LEMO power cable to power directly from any 2-pin LEMO auxiliary power output - featured on cameras such as ARRI ALEXA/AMIRA and RED's QUICKPLATE MODULE. You can also use a 4-pin LEMO to 2-PIN LEMO power cable to power from RED's +1 Adapter Module.
Two 1/4"-20 captive screws allow for secure mounting on may popular cheese-plates and handles including products such as Backpack Adapter Plate, DSMC Tactical Cage, DSMC Tactical Ribcage and ViewFactor FMJ-SideArms.
Stop buying poorly made plastic P-Tap splitters that are considered consumables. The HOTTAP is the last P-Tap splitter you will ever have to buy.
The HotTap 2 is exactly the same as the HotTap - but is slightly longer to include a USB for power output for charging mobile devices on camera and/or a USB light to use as a lens light. The HotTap 2 will ship AFTER initial orders of the HotTap, HotLink & HotBox ship.
*HOTTAP ORDERS BEGIN SHIPPING the Week of October 6th - first come, first served.
MADE IN NYC
- See more at: http://offhollywoodny.com/store/hottap/hottap-2/#sthash.feQn26rP.dpuf
https://vimeo.com/105733079
HOTBOX R/S WiFi
Featuring:
MADE IN NYC
Temperature Range:
MADE IN NYC
HOTTAP
MADE IN NYC
