Bruce Schultz
I could use some expert advice about getting Red 5K Dragon footage to match 4K Sony log footage shot on a documentary project.
I am having troubles getting the colors - especially red colors to match and I know this is a common problem, but what I need advice on is a workflow that would incorporate the very best elements of IPP2 and/or ACES in order to get the two cameras to color match. For instance, can you work with both cameras on the same timeline or do you need to separate them, process them separately and then recombine them with a saved look?
I am familiar with the IPP2 workflow and have found that it does a great job standardizing Red colors. ACES seems to be the necessary process for color standardization between the Red & Sony, however I have not yet explored the workflow to get this working. I'm just discussing colors at this point, tone/contrast adjustments are a more straightforward process of course.
If anyone can direct me to a tutorial or just explain a simple version of the Resolve/ACES workflow for these two different cameras, I would be most appreciative.
