Adam Johnson
WOW that's amazing!!
So I assume one would not be able to do a roll or dutch move with the joystick or remote during operation similar to a pan or tilt? Basically going from normal perspective to dutch angle?
If I understand you correctly, then yes you can. You can use the joystick to set any angle and then you let go of the joystick, then it would lock the roll at that place and stabilize it.
