GROUP BUY – OSEE LCM215-HDR 21.5" 10bit Monitor Kit
Added everyone! A third of the way there. No need to tell me about battery mount or accessories, as I believe what will be dispatched is custom coupon codes for their website where you will be able to pick out everything you want and get your discount.
Great! I am consulting with them about this right now. It sounds like they are going to ship the monitor + accessories in a mold (foam I believe) that will be a perfect fit for a specific Pelican case. So basically it will come in it's own custom cut foam, and if you need a case you can buy the corresponding Pelican case without foam for a perfectly customized case. Which I think is a great idea.
Do you know which case this is?
Will they be rolling out monitors like some Group Buys or is this just to get the price down, and they'll ship them all on the 11th or whatever?
Props to OSEE
Props to OSEE
Love the concept of shipping this type of gear in precut foam designed to fit industry standard cases! Due to the delicate nature of devices like monitors vendors can't avoid the cost of creating robust shipping solutions. So why not make it a value add, instead of expensive waste. Here's to hoping this becomes SOP!
Cheers - #19
It doesn't look like it from the pictures, but since they might be pre-production photos I thought I'd ask, does the monitor support 100mm VESA mounts? I'm not sure how I feel about their proprietary c-stand adaptor.
Finally have answer that yes it does have VESA mount. You remove the c-stand adapter to access it.
+1 v-mount
I wanted to know about this as well. I need a second monitor by the 16th and wondering if I'll have this by then or if I need to rent one.
Don't count on it as there are a few tweaks to the monitor casing that are happening as we speak.
