- Thread starter
- #161
Joel Voelker
Certainly an interesting theory but why would it do multiple cycles without attempting to update the firmware then all of a sudden decide to do so?
So i had a similar issue on an Epic-X. Camera on most current firmware, media loads in camera with extended wait time. Tried to reformat. Tells me format failed. Tried to load on computer. It will not see the card at all. 240GB 1.8 SSD. Card sent to red. Just got a repair cost from RED ..... =(
I had a renter report this as well few weeks ago with a V-Mount brick. I doubt though it's related.
Throwing stuff at the wall theory... Camera decides to update Mag's Firmware during Boot cycle effectively corrupting "boot Sector" or File Allocation Table of Drive?
Another theory:
It may be possible that you ALSO have corruption of the internal (non-SSD) storage within the camera.
I've had exactly the same SSD error ... and a few others in the last month.
http://www.reduser.net/forum/showth...-Not-Working&p=1691168&viewfull=1#post1691168
AJ
+) SSD : "The media in the Side SSD is not formatted correctly to work with this camera. Do you want to re-format it now" One off problem. Rebooting the camera .... and magically, the SSD was fine.
Hello all, I have experienced the dreaded "card not formatted for use in the camera" on the first day with my new Epic-W. It was the 2nd roll and happened on boot up after shifting location. Power shutdown was normal. Card formatted in camera. I have submitted a ticket and uploaded my log file.
I will not power up the camera with media attached for the remaining 2 days of my shoot.
Any advice for the mag that had this issue? How likely is it that the data is gone. FW 6.3.75
Been using RED for many years and never encountered such an issue. Anyone else experienced this recently as this thread has been inactive of late?
Subscribed to this thread, as I'm curious to find out the culprit. I'm on my way to get my first RED and there is no authorized dealer or service centre in my country, thus makes me a little bit worried.
I suppose SSD drives are highly sensitive to static charges, maybe some power fluctuation or electrical spikes while powering up..? Just a wild guess![]()
NEVER power cycle the camera with a mag in it. And then you should, likely, be fine.
Here's a recent "Side SSD is not formatted correctly" issue on an Epic Dragon running latest firmware, on a 240 mag:
http://www.reduser.net/forum/showth...ormat-failed&p=1685580&viewfull=1#post1685580
I've asked Willem to keep us posted on what's happening to him.
Worth noting the error message listed in that thread:
"The media in the Side SSD is not formatted correctly to work with this camera. Do you want to re-format it now?
Is exactly what we got when the Stormtrooper Helium booted up and deleted our 512 mag.
This is a reminder that this "Side SSD is not formatted correctly" behavior is def NOT isolated to DSMC2, but is also happening to DSMC1...
Whether this is firmware related is unclear, as that is something that RED would have to confirm.
Just keeping you all posted.
Have red actually suggested you have to remove media on power cycle?
A quick update from me.
512 card en route to RED for data recovery.
On day 3 of the shoot I had the same error message again. This time it was not on power up.
Upon triggering record the camera CUT itself and after a menu hang up once again the dreaded "card not formatted for use in the camera" message.
We had done 4 set ups on this card, which we quickly had to re-shoot.
Due to limited media we did a quick a quick secure format and then the card worked fine for the rest of the night.
Red are now analysing the log file and will get back to me. Hopefully this can be addressed as soon as possible.
This is the first job for this camera : ( and my Epic-W has already forced me to re-shoot 8 set-ups.
