Ryan Lalonde
blank
Have the team at RED acknowledged the fan noise issue at all?
Just wondering what can be done technically to improve this issue - apart from the fan noise we love the Epic but for long interviews which can often be about personal and sensitive issues, the fan noise during and between takes kills the moment and for now is making us consider alternative cameras for interviews.
Scott
Hello,
I did a non scientific test...
At 21 Celsius room temp
Fan @ 25% = 8-9 min
Fan @ 28% = 9-10 min
Fan @ 30% = 12 min
recording before 100% fan kiks in.
Pat
Wich Sr. number do you have? Is it an X?
Pat
(Snr. Epic-X2013 delivered 02.2012 is subjectively ok)
What power source were you using?
What recording setting were you in (18:1 > 6:1
Cheers
Antonio
Getting the mic 15 inches away rather than 18 and the camera 7 feet away not 6 could just make all the difference.
Hello,
Fan @ 25% = 8-9 min
Fan @ 30% = 12 min
Pat
Well, your examples reduce the noise only by about 1.5dB. Not very much.
This is only a suggestion, but note that there are ways to cancel and/or filter out some (I emphasize some) of the fan noise in post.Wondering if anyone else has had a similar experience or has any advice on how to keep the fan from starting spontaneously during an intimate interview in a quiet room that may require long clips rolling continuously.
"Extremely" is not a word I would throw around. Everything you remove creates artifacts. There are no precise surgical solutions that are perfect and artifact-free. It's possible to take bad sound and make it barely tolerable, but it's not possible to take bad sound and make it good. We can take OK sound and make it much better. Good sound does not happen at the push of a button. I wish it was that easy.That said a steady noise is extremely easy to remove in post. Just record a room-tone.
