Stacey Spears
- Sep 15, 2007
- Age
- 56
- Sammamish, WA
- www.spearsandmunsil.com
Here is a clip from the Xyla-21 tests that Gavin and I did. I provided ~5 frames of each, so you can run ADD if you like. The left couple of steps on the MX are masked off. I could not find a similar one for Dragon where we did not use frame averaging. To be clear, frame averaging was not used on either of these clips.
1. Noise level on MX is similar for red and green channels and noticeably worse for blue. To be expected given the light source.
2. Noise on dragon is lowest in the green channel. Red noise is higher, close to blue.
3. I set both clips to ISO 2000 and both are on RC3 / RLF to make them as equal as possible. Of course it is metadata, so you can change it.
4. I white balanced on one of the steps. I don't remember which one.
5. I think the noise on Dragon is finer than MX, but you can see it is reddish.
6. Matt, I figure you can post images as you are good at that sort of thing.
If you do, you should post two Dragon's, w/ and w/o ADD for completeness.
7. The test clips http://www.spearsandmunsil.com/sspears70/red/06_09_14/epic_noise.zip
