DAVINCI RESOLVE and ***HACKINTOSH HP Z800***
Hi Luigi,
I have everything I need to start building this beast, although I'm still waiting on a few pieces like the Decklink card and a new Monitor. As I get started putting in components I had some questions.
In post 1 you say that the SATA or SAS drives work, but you note in photo 4 that you should connect drives to the SAS ports. Do the SATA connections on the board not work?
Also, I notice it looks like you removed the DVD drive in your machine. Did you take it out since it didn't work or was it because you wanted the space for your 4 bay drive insert? Or maybe it just doesn't work in the SAS ports.
Finally, the machine came with 3 gigs of ram and I bought 24 more gigs (3X8). Should I just pull the 3 gigs and only use the new Ram or should put the new Ram in slots 2,4,6? More Ram is usually better, but I couldn't find anything that showed this configuration supported. I just want to make sure I have the most stable machine possible.
Thanks again for your help.
Walter
Hi Luigi,
Walter
CIao Walter,
it sas, no sata / sata port not work.
Yes I removed the DVD, did not help me, I put a bluray, usb Lg.
The qualtita is the same, important modules ECC ram.
I send you FTP access for download.
Thanks Luigi
--LITTLE UPDATE..
added ATI 5770 single-slot Radeon cards GUI support...
thanks
Luigi
Luigi,
I've got to say BRAVO to you! I've been watching you single-handedly show Redusers that creating a hackintosh is possible in the Davinci forum. And now you are packaging up a HP-based solution that you already troubleshot, and supporting people's first foray into this scarey water, and doing it for free!!
If Reduser had a reward for meritorious service, I'd nominate you. Thank for your generosity!
:thumbsup:
-Paul
Hi Luigi,
If apple does not announce a new Mac pro in the next two weeks I must build a resolve workstation without them. I like the idea of the hpz800 as an "off the shelf" hackintosh solution. As I really have little knowledge about building win pc, I plan to just follow your config and parts list exactly to give myself the best chance of it working right away. My only question is...the z800 is no longer made right? Do I have to buy one used? But it seems the z820 is not shipping yet? Where do I get a z800?
Thanks for your awesome dedication to this solution.
Edit...ok I see z800 are still for sale on hp site and earlier post has link to discount reseller. Of course I am confused by the endless variations available. But the single processor 6 core sounds like a good place to start. Then if apple comes out with new Mac pro later, I don't have $5k invested in a pc.
Last question...2 x gtx 580 3gb best price/performance and is there room in the z800 for both plus GUI card, plus hba, plus decklink?
[COLOR=#FFFFFF !important]
Luigi,
:thumbsup:
-Paul
[/COLOR]
Eheh you're always too kind, thank you Paul Nordin.
Hi Luigi,
[/COLOR]
ciao Paul , second Paul ahaha
you wait and see if anything happens, but according to Jeff Kilgroe the output will bescheduled for the end of this year, I hope you're wrong, but usually never wrong. is very accurate.
Well configurations tested by me are these:
1 CPU or 2 CPUs, 4 cores to 6 cores all is supported.
RAM from 2 GB to 96GB, plus I did not eheheheh
gui card: 8800 gt, 9800 gt, ati 5770 all single slot card.
cuda card: from gtx 460 to gtx 590
sas ports: all working, I'm testing also hot swappable. So to put some on the removable tray.
power: 850 w is ok from gtx 460 to gtx 580 3gb, if you want ussare the gtx 590 you must have 1100 watts.
dvd recoder: supported.
fire wire 400: 2 doors both worked.
USB: all ok
Audio onboard: works but creates problems, I have disabled the default, use usbspeakers. BM or AJA Kona and output with XLR.
My best configuration to be the following:
hp z800, 2.93 8 core, 48 gb ram, 8 hd installed, 1 for os, 4 raid 0, 3 for all-in internalbackup machine.
A 8800 gt 512 ram for gui, 1 for cuda gtx 590, 1100 watt power, bm 1 3d, 1 redrocketcard.
With this configuration I have no problems.
I recommend 1 gtx 590, although not as fast as 2 GTX 580 by about 20%, but you gain by having 2 gpu on a single card, but above all less heat inside the machine, which is important given that ventilation be air.
I state that right now I recommend 2 cpu, if utlizzate Adobe cs6, but if you use only 1cpu Davinci also goes very well.
I took everything used on ebay, the IT company CREATIONS, fast and friendlyproducts are good, the machine empty with 18 gb ram 2.93 ghz have paid 2100dollars.
But if you find any better.
If you're worried about your configuration does not worry me lend a hand with noproblems, though sometimes I prepare you already lion on the system hard drive and I send him there, so just worry about installing the rest of the PC.
THANKS
LUIGI
Thanks Luigi!
I will start looking for z800 dual 4 core CPU. I think I will risk the heat and go with 2 gtx580 as I think Peter at resolve says more gpu ram = less " out of memory" errors with 4k media.
You are a great help and I will try not to ask too many stupid questions!
Thanks Luigi!
remember that it can at most have 2 video cards in the HP z800, in your case you would have a gtx 580 for the gui and 1 gpu for cuda.
and 1 card for 4k is not good.
Luigi
Does pci esata card work? I need esata to transfer client projects to raid. I am thinking about getting:
Decklink hd extreme 3d
Gtx 590
Ati 5770 ( I need for apple color still!)
esata card
raid card (hi point rocket raid 2722
Will this combination work? Of course 1100wt power too
Gtx 590
esata card
yes work..
but the fast machine with Davinci and Premeire cs6 is whit 8800gt not ati 5770 :)
Luigi
Luigiluigiluuuigi... we now bought this here: 2x 4-Core Z800! :beer:
Prozessoren: 2x Intel® Xeon® Quadcore-Prozessor X5672 (3,20 GHz, 12 MB Cache, 1333 MHz Hauptspeicher)
Chipsatz: Dual Intel® 5520
Speicher: 6x2 GB =12GB Hynix 2Rx8 PC3-10600E Model: M391B5673FH0-CH9
Interner Speicher: 2x300 GB SAS Festplatte Model: ST3300657SS
Grafik: NVIDIA Quadro FX3800 (1 GB)
We now do need a switch for 2x HDMI and 2x USB (Mouse and Keyboard). Do you know a good hardware.
Maybe i will test your Machete! Does it work with the FX3800 and a GTX 285 as 2nd gear? ;)
all ok but not fx3800.. no have patch for this..
i repeat gui card is 8800gt,9800gt,ati 5770 single slot.
thanks
Luigi
Hi luigi, awesome work with z800!
Do you know why is not possible gtx in external pci extender?, why it is possible with mac pro but not possible with hackintosh?.
I ask because i have a netstor working perfectly with 2 gtx480 under 10.6.7, but i cant make it work under 10.7.3, maybe the problem is aty.init... I need to fix thisss!! I like a lot my netstor
Ciao Jose,
if you use new driver Nvidia 10.7.3 not use aty.ini possible to conflit, with new driver nvida is not necessary aty.init...
you are in hp z800?
ciao
luigi
