Wayne Morellini
- Jan 3, 2008
Now, yes, the upgrade path was a bit awkward. To do upgrades you need a clearly definable swappable parts strategy. So, say if the Red One was designed to be upgradable. You could have a sensor module that slid out the side, boards that slid out and new ones slid in. But ultimately, post all in one bodes, you just swap the redording head module out (brain) for a new one and resell the old one, maybe to a rental company. If you can't easy swap things inside these things then it is problematic. Going back to the Red One, and say if it had been designed to be easily upgradable, but the new stuff couldn't fit (as happened with the Scarlet) then latter when things can fit you could have swapped in a helium sensor and modern redcode. But this hasn't happened.
