Aaron Lochert
I'm not sure you get much out of a s35 or Dragon sized version of the Monstro. It works in conjunction with the 8K resolution.
Better dynamic range, totally usable at 6400 ISO, and in camera IPP2?
Like you I have no audio issue with my Epic-W with v lock, just dont put crap in front of it!Right, but Monstro hardware, but just like Helium, Monstro likely needs the bigger hardware to drive it.
I haven't been having any real audio issues with DSMC2, but I think it's largely dependent on workflow and environment. We're finally getting more audio Modules/Expanders though.
We'll see what RED does on the fan front though. The DXL mainly needs those fans for the additional hardware found within.
Actually if we remember Jarred's Ranger posted forever ago, there's also some new airflow there, but for similar reasons to DXL.
For audio just calibrate at a higher temp and you camera is suddenly very silent...
Guess I'll never shoot with it below 8K?That's like saying you shouldn't shoot with Dragon or Helium below 8K or hell 6K or 5K.
The real question is "if RED will do it and when".
RED's already demonstrated that Monstro has a lower noise floor, more sensitivity, and more accurate color than Dragon at 100% resolution (which I'm real eager to test fully btw). So if they can make a 6K or 5K cut, it would make sense to fill out those camera lines "perhaps" down the line.
It might also be a bit weird to do with Helium being also good at 8K already in the S35 format size.
We'll have to wait and see.
For now, Monstro is going to show it's initial strength in 8K VV and of course the various other formats and resolutions you can shoot below 8K.
I personally think there is a market for 5K and/or 6K cuts for those who are focused on delivering 4K or lower, but that's just me.
At the moment however, my big interest in Monstro is it's apparent better image performance, integrated IPP2, and delivery 8K and 4K material.
+1 for 6K monstro crop
For audio just calibrate at a higher temp and your camera is suddenly very silent...
A 6K Monstro Sensor in an Epic-W would be DREAMY.
So... going back to be a slightly better Dragon? I think you better keep the Helium :tongue_smilie:
I would love to have a Epic-W with a 8k VV monstro sensor at the same frame rates as the Epic-W with helium. That would for sure be worth a 10K upgrade for me. I'm hoping that a year from now the sensors swap is available for epic-W as well.
I'd rather the 6K Monstro, for numerous reasons...improved Dragon sounds GREAT to me....less data, less crop on slowmo, improved rolling shutter, etc...
The ABT Speedbooster seems like a nice option but it does have its limitations...
Curious about Duclos's upcoming speedboster too, maybe a newer, original optical design?
Yeah, indeed is what I do too but just a little, how much have you actually pushed to?
Thanks Mika!
