Mark Deeble
- Aug 20, 2010
- Kenya
- www.deeblestone.com
Doesn't make much sense to use lenses optimized for 35mm format cameras on a 16mm sized format.
David, it does if you are shooting wildlife, where for a couple of decades the 'standard' lens for 16/S16 was a converted 300mm 2.8 Canon. There are still masses out there. Users benefitted from the 'telephoto effect' of using a 35mm lens on the smaller format and also using only the centre of the 35mm image circle.
