Mark L. Pederson
REDuser Sponsor
The Future has no moving parts.
An no whale oil ... or synthetic lubricants ...
Well with respect... the off the shelf reference has nothing to do with the scenario I highlighted earlier. If you are recording about 500 hours of footage per day... then it becomes way more costly to use HDD or solid State based media.
That would be $25k of tape stock per day.
Over $8.5Million dollars in tape stock if they sustained
that over the 340 days.
Reusable media would have been more cost effective, I think.
I don't know anyone that reuses tape for serious work and even so there's a point where the tape wear does start to cause problems. I've reused my red drives hundreds of times.
You take the documentary that was highlighted in the Sony reel... Oceans... if that was done on Solid State, Compact Flash or HD Drives... how much money would that cost? Tape is a great solution for those type of workflows and nothing else beats it. Lets look at the issues posed in those workflows... 500 hours of dailies per day recorded at a high data rate of say 440 or 880 Mb/sec. I can't see any other way those projects can get done other than tape.
And in that underwater application, a 128GB RED-RAM sounds like an excellent fit for the 45 minute loads that they were shooting.
this is going to a silly discussion. of course you can shoot 45 min underwater on a red ram, but if you want to do that more than one time a day and maybe more than one day in follow you have to unload all to a hard drive system. means one person more to do that. there are enough job in the industry where tape is great alternative, especcialy for those walking thru the jungle for several days without any possibilities to charge battery or to have power.
And yes, tape can get mold, it´s not sealed, it rusts - but have you ever seen a hard drive fallen down from a table and tried to unload the data?
lets stay serious guys - this is not a format war - the question is more the performance of a camera !
Is anybody really doing this? That is 20 cameras rolling for 24 hours straight!
Or more likely 100 cameras pulling about 5 hours each of footage per day.
Building that kind of footage for a project is typically done over a much longer time frame.
The under water video samples in the sony press release were phenomenal...regardless of the format the did an outstanding job, so if they are reading, bravo.
I misinterpreted that part about the dailies... but with 19 teams... who knows how much footage they were capturing per day. 19 teams does not mean 19 cameras. It could be more. The RED RAM only captures 78 minutes of footage at REDCODE 28. My argument is still valid. How many RED RAM drives would they have to supply to 19 teams? How would the offloading be done in the field? Especially when the teams are spaced out around the world in the ocean?
You'd use firewire drives to off load like everyone else. You claims of high cost for SANs, etc isn't really applicable to the way most people are working. Big storage arrays are used for editing and accumulating huge amounts of footage. It's not something that needs to be done in the field. If you were hdcam-sr you'd still have an avid or fcp system with a big raid with all your dailies.
IMHO, reddrive is great for underwater at 3 hours of footage and it's cheap
and can be used hundreds of times. It takes only 10 or so reuses to beat the cost of SR tape. a couple more to pay for the offloading cost of the hard drive.
Tape has it's place for now but it'll be dead soon enough.
If sony didn't think so they wouldn't be scrambling towards an SSD solution.
Then please explain what the workflow is for duping a tape out in the wilderness is so you can reuse tapes (since you mentioned tapes are easily reusable). I use multiple red drives for nature work and dupe when I get back to the car or hotel. I can't do that with tape and I absolutely need 2 safety copies before I fly.
You keep trying to skew your arugument into areas that tape does well but there are just as many problems with it that you have to work around. Each has different workflows and advantages.
I wouldn't have to dupe with tapes thats the entire point. Bring along 25 HDCAM-SR tapes at a cost of $1875. Compared to a RED RAM Drives at $122,500.
